Is this article legit and true?
Old Apr 19, 2006 | 11:59 PM
K-Spec's Avatar
Default Is this article legit and true?
Just wanted to know what your opinions are?
http://www.mototuneusa.com/break_in_secrets.htm
Old Apr 20, 2006 | 04:10 AM
VTI Brazil's Avatar
I have 3 friends who used this method and gain real hp's.
I'll use it when open my engine!
Old Apr 20, 2006 | 05:42 AM
98vtec's Avatar
moderator emeritus
Default Re: (VTI Brazil)
its what i am going to use.
Old Apr 20, 2006 | 06:48 AM
NoVALude's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">its what i am going to use.</TD></TR></TABLE>
X2
Old Apr 20, 2006 | 07:38 AM
plikit's Avatar
Default Re: (NoVALude)
worked for me
Old Apr 20, 2006 | 08:15 AM
K-Spec's Avatar
so as soon as the car warms up to operating temp...just revv the **** out of it? I mean just put it in vtec as much as you can?
Old Apr 20, 2006 | 08:27 AM
fzr's Avatar
fzr
Default Re: (khalal538)
I think he means a little more than just "revving the **** out of it"
He stresses running it under load, and that it's important to engine brake as much as it is to accelerate hard.
My sisters boyfriend has been doing this to his brand new MX-5, I'll be interested to see how it turns out!
Old Apr 23, 2006 | 12:23 AM
K-Spec's Avatar
so...when breaking in the engine by driving hard...would you use synthetic oil or conventional oil to have the piston rings sit properly?
Old Apr 23, 2006 | 06:28 AM
93h22a1vtec's Avatar
i used this method, or a similar method of break in... havnt had any problems... LOAD in the first 250miles is crutial. And use conventional oil for the first 2000 miles then switch over to synthetic.
Old Apr 23, 2006 | 06:41 AM
97Preludeguy's Avatar
Default Re: (93h22a1vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">so...when breaking in the engine by driving hard...would you use synthetic oil or conventional oil to have the piston rings sit properly?</TD></TR></TABLE>
Yea, if you read the damn thing you woulda seen it said to use conventional
And the point is to vary the RPMs alot. Don't just drive in 5th gear at 130 for 30 miles because "the RPM is high". You're supposed to do short bursts, mostly in 1st, 2nd, and 3rd gear from say, 3 grand, to redline then stop, then cruise, then again, etc.
Old Apr 23, 2006 | 02:24 PM
unusual71's Avatar
remember to pay attention to everything thats going on when your doing this too (as you'll probably be having fun) dont forget to glance at the temp and listen for any detonation or other weird noises.
ej1252
Nov 28, 2007 08:35 AM
BJA86
Audio / Security / Video
23
Nov 11, 2007 04:01 PM
unknown0001
10
Jul 4, 2005 11:12 AM
morepoop4u
Nov 3, 2003 03:00 PM
superteg_21
Jul 13, 2003 12:47 PM
