Header Glow Problems
Old Apr 21, 2006 | 09:00 PM
RudeLudeHatch's Avatar
Default Header Glow Problems
Just got the 2.2 running after a tps failure. Now my headers glow, its smoking from somewhere, but these are new headers so there not worn out peices of shi*. I heard this can be caused by......retarded timing..running rich or lean....spark plugs??? I dont know which.. At the same time the both hoses from the rad are pressurized like a **** and feel like there gonna pop whats this from. where do i start ? Can't drive it cause it boggs out as i open the throttle.. Need expert help!!!!
Old Apr 21, 2006 | 10:36 PM
hondamanmark's Avatar
usually when your header gets that hot and glowing.....something to do with your exhaust isnt right....like a leak and no good compression......or something is burning waaaay too rich
Old Apr 22, 2006 | 03:52 AM
championshipwhite93si's Avatar
Default Re: (hondamanmark)
yeah either that or you just were rolling in excess of 110 plus for over 50 miles....
Old Apr 22, 2006 | 05:18 AM
mgags7's Avatar
Default Re: (championshipwhite93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by championshipwhite93si &raquo;</TD></TR><TR><TD CLASS="quote">yeah either that or you just were rolling in excess of 110 plus for over 50 miles....</TD></TR></TABLE>
wtf?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamanmark &raquo;</TD></TR><TR><TD CLASS="quote">usually when your header gets that hot and glowing.....something to do with your exhaust isnt right....like a leak and no good compression......or something is burning waaaay too rich</TD></TR></TABLE>
hot=lean
not rich
sounds like you could either have map sensor problems or possibly something blocking your exhaust.....check your cat and catback.....
Old Apr 22, 2006 | 07:46 AM
ludiferino's Avatar
Default Re: (mgags7)
As mgags7 said, glowing header = vrey high egt.
Excessive egt comes from running too lean, or an obstruction in the exhaust/cat.
Old Apr 23, 2006 | 10:13 AM
Default Re: (ludiferino)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
wtf?
hot=lean
not rich
sounds like you could either have map sensor problems or possibly something blocking your exhaust.....check your cat and catback.....</TD></TR></TABLE>
ran at lime rock last year for better than an hour and my header was glowing red... that why i said at over 110 mph for a continuous period of time.. dont go acting stupid when someone replys something like that. not everyone is a ricer.
Old Apr 23, 2006 | 10:36 AM
HOsNiDA's Avatar
Well if you maintain 110 mph for awhile your motor is under alot of pressure and you are running around 5 or 6k on you tach if im correct so. THINK ABOUT IT.
trrbl1bmx
Jan 29, 2007 06:41 PM
coolgsrguy
Mar 26, 2006 12:17 AM
ragethemachine86
Mar 16, 2006 01:11 PM
SpoonFedHatch
Apr 26, 2004 02:34 PM
mustbenu
Mar 18, 2004 10:08 PM
