Help bad compression numbers
Old Apr 24, 2006 | 08:01 AM
92lude91rex's Avatar
Default Help bad compression numbers
hey i got compression numbers 180-190 across the board and my cars feels slow its a jdm h22. Ive searched and seen people getting mid 200's for their compression numbers ..... now the question waht do i do??? I want to build the engine for turbo eventually so if that helps....??
Old Apr 24, 2006 | 08:02 AM
Default Re: Help bad compression numbers (92lude91rex)
by the way its a 92 prelude si with the jdm h22 swap out of a 95 jdm lude
Old Apr 24, 2006 | 08:28 AM
syntax.'s Avatar
you can pull the spark plugs and squirt a few drops of oil into each cylinder and recheck the compression. If the numbers are significantly different, they its likely that bad rings are causing low compression numbers.
Old Apr 24, 2006 | 11:11 AM
Chuckles99SH's Avatar
Default Re: Help bad compression numbers (syntax420)
Check your timing, if your timing is off it might throw off your #s. The main thing that is good is that all the numbers are within 15psi or so, i think they say if its between 30psi max then you are ok.
Old Apr 25, 2006 | 05:41 AM
Rosko's Avatar
Default Re: Help bad compression numbers (Chuckles99SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chuckles99SH &raquo;</TD></TR><TR><TD CLASS="quote">Check your timing, if your timing is off it might throw off your #s. The main thing that is good is that all the numbers are within 15psi or so, i think they say if its between 30psi max then you are ok.</TD></TR></TABLE>
ignition timing has no effect on compression #'s, unless ur talking about camshaft timing/overlap.
huge230
Oct 2, 2005 10:40 AM
jdmcivicferio
Jun 2, 2003 01:14 PM
SmurfDA
May 13, 2003 06:05 PM
