valve spring and retainer install
Old Jun 21, 2006 | 06:07 PM
90AccordVTEC's Avatar
Default valve spring and retainer install
I want to install uprated valve springs and titanium retainers in my H22A but i would like to know if it is possible to do without removing the head. Anyone know? Thanks.
Old Jun 21, 2006 | 06:10 PM
92bluepreludeSi's Avatar
Default Re: valve spring and retainer install (90AccordVTEC)
im sure you would have to remove the head.
Old Jun 21, 2006 | 06:59 PM
oranginal's Avatar
i had to remove my head to install them
Old Jun 21, 2006 | 07:26 PM
98vtec's Avatar
moderator emeritus
Default Re: valve spring and retainer install (oranginal)
you can use an air compressor to pressurize the cylinder so the valve didnt fall down when you pulled the retainer off. Just remember to have that particular cylinder at TDC so you dont lose the valve and be forced to take the head off.
Old Jun 21, 2006 | 08:51 PM
Rosko's Avatar
Default Re: valve spring and retainer install (98vtec)
I've done V8's with air but it might be hard to get your fingers down in there on a Honda.
Old Jun 22, 2006 | 04:33 AM
bluedlude's Avatar
i didnt think it was possible because you have to compress the spring to get the retainer off right?
Old Jun 22, 2006 | 04:51 AM
Pullig's Avatar
Default Re: (bluedlude)
ive done it numerous times it can be done with the head on. you just need the snap on tool ohc spring compressor . Fill up the cylinder your working on with air to abt 100 psi and you should be good
j spec
May 14, 2006 02:54 PM
qcktegls
Nov 17, 2004 10:19 PM
Steve91
Sep 19, 2003 11:53 AM
JunIntegra
Apr 11, 2003 05:15 PM
jabroni95gsr
Nov 19, 2002 08:17 AM
