Map sensor and EGR plates
Old Jun 27, 2006 | 07:59 PM
blue153's Avatar
Default Map sensor and EGR plates
what are the egr and map sensor blocking plates used for? i know the egr blocks the exhuast air from recirculating back into the motor. anyone know the advantages/disadvantages of these? will you still pass emissions with these things blocked off?
Old Jun 28, 2006 | 04:55 AM
blue153's Avatar
Default Re: Map sensor and EGR plates (blue153)
Old Jun 28, 2006 | 08:40 AM
Hawkze_2.3's Avatar
I passed emmisions with my EGR blocked off.....I don't know why you would want a MAP blockoff plate though
Old Jun 28, 2006 | 12:51 PM
blue153's Avatar
Default Re: Map sensor and EGR plates (Hawkze_2.3)
i'm building a h22/f22a motor and i'm droppin it into a 92 integra. i was told from someone that the egr and map sensor was a pain to deal with and to block them off with KMS plates.
Old Jun 28, 2006 | 11:53 PM
JDM_COUPE's Avatar
egr is a pain map sensor aint a pain. its just 3 wires, plus most h22s dont have a map sensor on th TB its on the firewall. hence no map sensor bloack off plate is needed
Old Jun 29, 2006 | 10:36 AM
bluedlude's Avatar
so what, its reading the air pressure across the firewall? i know MY, MAP sensor is on top of my throttle body. wouldnt taking that off totally mess up your cars tuning? isnt that where the initial air readings are coming from to adjust the fuel curve? how could you take it out.
Old Jun 29, 2006 | 10:59 AM
Hawkze_2.3's Avatar
Default Re: (bluedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">so what, its reading the air pressure across the firewall? i know MY, MAP sensor is on top of my throttle body. wouldnt taking that off totally mess up your cars tuning? isnt that where the initial air readings are coming from to adjust the fuel curve? how could you take it out.</TD></TR></TABLE>
As long as the MAP sees the engine's vacuum it's fine. You can hook it up to a vacuum line attached to the intake manifold and it's the same thing as having it mounted onto the intake manifold. You definately can't just get rid of it...
allnaturalb16
Oct 19, 2007 10:14 PM
reddysol
Sep 8, 2007 10:57 AM
methos713
Jun 11, 2007 12:43 PM
