need a spring compressor?
Old Jun 29, 2006 | 01:39 PM
budget's Avatar
Default need a spring compressor?
do u need a springs compressor to take off your springs if using an impact with agx shocks or will it not fly off
Old Jun 29, 2006 | 01:44 PM
98vtec's Avatar
moderator emeritus
Default Re: need a spring compressor? (sackNsave)
i've never used a spring compressor...but im ****** crazy and dont have the patience to fiddle with those things
air gun + trash can =
Old Jun 29, 2006 | 01:45 PM
iLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackNsave &raquo;</TD></TR><TR><TD CLASS="quote">do u need a springs compressor to take off your springs if using an impact with agx shocks or will it not fly off</TD></TR></TABLE>
I've taken them off both ways. I really don't see a reason not to get a spring compressor. You should be able to rent them at your local auto parts store...
Old Jun 29, 2006 | 01:51 PM
chitownrida's Avatar
just go down to your local vatozone and put down a deposit to rent them
Old Jun 29, 2006 | 02:01 PM
darkspector's Avatar
I've seen people wrap towels around a couple coils compressed and tie them off.... so ther is less springing when you take off the top hat
Old Jun 29, 2006 | 02:36 PM
Mr.Slippyfist's Avatar
Good to AutoZone, they are FREE
Old Jun 29, 2006 | 03:33 PM
prelude1897's Avatar
When I did my suspension, I didn't use a spring compressor
Old Jun 30, 2006 | 05:25 AM
daoshao's Avatar
i didn't use one either with my first project but after getting more money....40 bucks for spring compressor is a good investment. I've used it over 8 times already. 4 yrs ago a guy working at a shop died in minnesota...spring shot out and went in his neck...
Old Jun 30, 2006 | 05:51 AM
esedulerp5tenin's Avatar
Default Re: (daoshao)
if your putting a TRUE coilover setup in, you DONT need a compressor, since you dont need to compress teh springs to take them out.
if your putting RACE springs in (H&R race, neuspeed race, etc) you DONT need to use a compressor to put them in, since the springs are short enough to fit on the shocks. (you'll prolly want the compressor to take the old springs off tho)
but since it sounds like your taking the stock springs out, a compressor will come in handy
just put a deposit on one @ autozone, and get the $$ back when you return it
Old Jun 30, 2006 | 10:45 AM
Altilude's Avatar
Default Re: (esedulerp5tenin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esedulerp5tenin &raquo;</TD></TR><TR><TD CLASS="quote">if your putting a TRUE coilover setup in, you DONT need a compressor, since you dont need to compress teh springs to take them out.
just put a deposit on one @ autozone, and get the $$ back when you return it </TD></TR></TABLE>
I agree with this guy... I bought a spring compressor for my lowering job. Removing the stock springs, from the stock shocks (to rob the other parts) I found the stock springs were under load, so a spring compressor might prevent an unlikely (but ever present) chance of injury - however fitting my eibach sportlines to my kyb agx, I found the springs were short enough to get it mounted without the spring compressor.
Dee A Nine
Aug 29, 2006 04:27 PM
mike9571
Nov 28, 2005 01:12 PM
Blazin Civic
Suspension & Brakes
15
Jun 20, 2005 05:53 AM
dungsta
Suspension & Brakes
May 2, 2005 10:34 AM
CRX-RX
Jan 23, 2002 10:49 AM
