need help with installing trunk spring
Old Jun 22, 2006 | 09:08 AM
businessmanph's Avatar
Default need help with installing trunk spring
searched already
my 01 prelude was missing a trunk spring
i just got a new one but i can't get it locked in. are there any tools/techniques to get it in.
Old Jun 22, 2006 | 09:12 PM
Default Re: need help with installing trunk spring (businessmanph)
bump
Old Jun 22, 2006 | 09:17 PM
ninja 6's Avatar
the forks that keep the trunk open?
Old Jun 22, 2006 | 09:21 PM
Hawkze_2.3's Avatar
Well, there is such a thing as a 'torsion bar assembly tool' that the manual says you're supposed use, but you may be able to muscle it in with a little creativity and basic tools....
Old Jun 22, 2006 | 09:59 PM
ninja 6's Avatar
Default Re: need help with installing trunk spring (Hawkze_2.3)
yeah. muscle it in. It takes a lot of strength.
I used some pliers as well to help.
Old Jun 23, 2006 | 07:00 AM
maks's Avatar
Woha crazy, I never knew there was a spring... I just assumed my prelude was designed w/o one!
Where did you find yours?
Old Jun 23, 2006 | 05:58 PM
bigz187's Avatar
Default Re: need help with installing trunk spring (maks)
the tension bars??
Old Jun 24, 2006 | 08:58 AM
djbrandonr's Avatar
Default Re: need help with installing trunk spring (bigz187)
its hard to explain but I had to do it once. Lightly bolt the left hinge to the trunk and set the bars on it. Leave the right one unbolted and get the rear bar mounted to the right hinge in the rear position. You should understand which one goes where by looking. Then get a wrench and put it inbetween the two end of the last bar and rotate the bar a good half turn or more toward the front of the car in clockwise postion. Hope that helps and makes sense.
Basically when the trunk is closed the bars are tensioned one way so that when you pop it the want to unwind and hence open the trunk. Kinda like winding up a rubber band. If you twist it to the left its gonna unwind to the right when you let go.
Old Jun 24, 2006 | 06:01 PM
Default Re: need help with installing trunk spring (djbrandonr)
i took my car to a honda prep shop and they did it for free. they had a lil L shaped tool. he got it on in 5 mins.
there is no way i could muscle it in. if i was superman i could
Blamm!!
May 9, 2008 08:46 PM
maxQ
24
Mar 10, 2005 03:21 AM
mark420
Sep 26, 2003 09:56 AM
43MA
Dec 10, 2002 08:18 AM
solo-x
Nov 3, 2002 05:35 PM
