End Link Problem?? I Think.
Old Jun 28, 2006 | 06:59 AM
barriecarson's Avatar
Default End Link Problem?? I Think.
Has anyone had problems with after market end links (progress) causing a 'clunking' sound in the rear suspension??
I upgraded to a Progress rear sway bar and Progress end links. Since the install I've been getting a loud 'clunk' from the rear drivers side when ever I hit a bump in the road. Not just big bumps either, small one's as well.
HELP. ANYONE???
Old Jun 28, 2006 | 07:32 AM
The Weather Man's Avatar
Well first off - check your strut tower in the back. The nut might not be tight enough.
Also, is it squeaking also? because that would indicate a blown strut.
Did u use bushings in the end link? If you did - and everything's tight, it shouldn't clunk.
Old Jun 28, 2006 | 08:20 AM
petern101's Avatar
Default Re: (That BEAST)
progress endlinks have been known to be "less than par"
and i am pretty sure the squeaking is normal on the progress endlinks
Old Jun 28, 2006 | 08:32 AM
Hawkze_2.3's Avatar
Default Re: End Link Problem?? I Think. (barriecarson)
I had that same problem with OEM endlinks and a Progress bar.
This should help--https://honda-tech.com/zerothread?id=1474587
Old Jun 28, 2006 | 11:44 AM
How tight is "tight enough" for the top nut at the rear strut tower??? can it be over tightened??
Bushings in the end links??? Explain??
Hawk, has the tape around the bolt held up???
Old Jun 28, 2006 | 09:01 PM
Hawkze_2.3's Avatar
Default Re: (barriecarson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by barriecarson &raquo;</TD></TR><TR><TD CLASS="quote">
Hawk, has the tape around the bolt held up???</TD></TR></TABLE>
Absolutely , packing tape is almost rock hard if it's wound perfectly tight. My suspension is totally quiet now.
Ritchie
Suspension & Brakes
26
Oct 16, 2010 09:29 PM
PatrickGSR94
Suspension & Brakes
Aug 23, 2008 11:30 AM
systemoverload
Suspension & Brakes
Apr 14, 2005 07:36 AM
Steve91
11
May 20, 2002 10:45 PM
