help
Old Jun 22, 2006 | 03:11 PM
fastbb2's Avatar
Default help
I have a 92 prelude with a jdm h22 swap. I have a skunk2 pro series intake manifold and a dc sports header, and a walbro 255 lph fuel pump. Now for the fun part, My car is running really rich ( 52psi) on a stock fpr now its hesitating and back firing and the cel is on. first off how do I get the fuel pressure down next how do I make It run better without spending a crap load of money to do so!!! and I can't find the service port to see why the cel is on I was told 2 places under the dash far left corner, under the kick panel on passenger side, Where the HELL is it?
Old Jun 22, 2006 | 03:13 PM
pizzamanprelude's Avatar
Default Re: help (fastbb2)
you could always just revert back to the stock pump, you dont really need more fuel capacity with just a few bolt ons, your not FI are you?
Old Jun 22, 2006 | 03:22 PM
98vtec's Avatar
moderator emeritus
stock fuel pressure is 45-47psi. And that fuel pump is likely pumping way too much fuel considering you have a stock motor with minimal mods
Old Jun 22, 2006 | 04:23 PM
fastbb2's Avatar
no fi just intake manifold and header the stock fuel pressure was 32psi I have a guage and It does work(i'm not trying to be a ***)
Old Jun 22, 2006 | 04:26 PM
98vtec's Avatar
moderator emeritus
32psi with the vacuum hose on or off? What is it with the hose off?
Old Jun 22, 2006 | 05:02 PM
fastbb2's Avatar
stock with the vacuum line off is about 45psi(with the stock fp)
with just the walbro and stock fpr with the line off is 62psi
I think my car has a mind of its own like the plymouth fury on the movie christine but hates me!
Old Jun 22, 2006 | 05:03 PM
98vtec's Avatar
moderator emeritus
dude thats WAY too much pressure. Put the stock pump back in there or get an adjustable FPR
Old Jun 22, 2006 | 05:05 PM
fastbb2's Avatar
Default Re: help (98vtec)
I had the b&m but the diaphram took a **** on me thats why I have the stock on on. still nobody has told me where the service plug is I want to know what is throwing a code
Old Jun 22, 2006 | 05:06 PM
98vtec's Avatar
moderator emeritus
well you need to do something because the fuel pump is the reason you are running so rich.
and i would get it done asap before you f*ck up the rings.
Old Jun 22, 2006 | 05:10 PM
fastbb2's Avatar
what if thats not the problem this car has surprised everyone I know.
people say its this or that but when I fix it it don't solve anything.
Please don't think I'm being rude to you I appreaciate all the help i can get
I'll put the stock fp on and i'll let you know what happens
thanks for your help
Old Jun 22, 2006 | 05:13 PM
98vtec's Avatar
moderator emeritus
62 psi on a stock motor is not needed and is the reason you are running rich. You have nothing to control the fuel which means the injectors are still opening and closing at the same speeds and simply pushing more fuel per cycle.
schpiel
Jul 10, 2008 01:08 PM
Budget Racer
Feb 8, 2008 05:26 AM
CFDOHCVTECEG
Feb 2, 2007 03:32 PM
cherroneballs
Mar 19, 2005 09:40 AM
Lei Siew Long
Jan 19, 2002 03:45 PM
