ATTS question
Old Jun 29, 2006 | 05:42 PM
vinuneuro's Avatar
Default ATTS question
Does it work off-throttle?
Old Jun 29, 2006 | 09:39 PM
honda_andy's Avatar
yes, i would also like to know this, would it work if you were taking a turn in neutral cuz technically there is no torque going to any wheel.
Old Jun 29, 2006 | 10:12 PM
jdmlude_dude's Avatar
Default Re: (honda_andy)
i believe it is all mechanical. any time the axles are rotating the mechanics inside the atts unit it is working
Old Jun 29, 2006 | 10:16 PM
honda_andy's Avatar
ya but atts is supposed to transfer torque to the outside wheel during acceleration in corners to prevent understeer, what torque does it transfer when you're in neutral?
Old Jun 29, 2006 | 10:40 PM
i dont think it xferrs the power from the motor. i think it is more the less the gravity and the force from the unit itself. Think that if that car rolls and you turn the wheel, no matter if the motor is on, the car can understeer. I would logically think that it can sense the amount of force put on a certain corner as well as use the torque from the motor to push toward that wheel. If i had to guess it would work just mechanically with the motor not on. With the motor on it can use the power from the tranny to push the unit to disperse power to the outer wheel.....it sounds good in my head anyway!
ltran82
Honda S2000
Oct 25, 2007 10:51 AM
BojeEM2
Honda Civic (2001 - 2005)
Mar 29, 2007 09:09 AM
5thGenCivicKid
Mar 14, 2005 02:44 PM
spyder
Jun 11, 2001 10:12 PM
