Third Gear Grind
Old Jun 23, 2006 | 02:10 AM
Goochmoney's Avatar
Default Third Gear Grind
All right i searched about the prelude transmission but i am still not sure if it would be my synchro that is blown. My gears seem to grind whenever i shift into thirs above a certain rpm think above about 4000. I was wondering if it could be my synchros even though the grinding starts while my clutch is still all the way in. A friend of mine told me it could be just that my transmission isnt aligned right but it seems as if the syncros would make since because of the fact it only happens over 4000 rpms. Just wondering if it matters that it happens before the clutch is being released. Shoots.
Old Jun 24, 2006 | 01:42 PM
Goochmoney's Avatar
Default Re: Third Gear Grind (Goochmoney)
Anyone?
Old Jun 24, 2006 | 02:11 PM
Pullig's Avatar
well im on my 2nd transmission now and its doing this also. The synchros are going out. My last trans starting grinding third then eventually started to lock me out of it if i was revving it hard and shifting. It eventually started to not even hold 3rd gear just kept popping out. You dont need a new trans right away but it is slowly but surely going out on you.
Old Jun 24, 2006 | 05:31 PM
AznBlueBoy's Avatar
Default Re: Third Gear Grind (Pullig)
try GM syncromesh....it could cure the problem for awhile....
or try a redline mtl
John 07
Sep 11, 2012 07:18 PM
gabe768
Jun 7, 2010 03:06 PM
JDMGSR-T
Oct 27, 2006 02:48 PM
SatinSilver_DC5
May 3, 2005 05:29 AM
hondafrk
Jun 29, 2002 10:53 PM
