High Idle!!
Old Jun 24, 2006 | 12:15 PM
Linh.'s Avatar
Default High Idle!!
I have a skunk2 68mm tb. On start up my car idles around 1100 rpm, once the car is warmed and I drive down the street the idle raises up to around 1500rpm. If I tap the gas real quick the idles drops down to 1100rpm and then proceeds to go back to 1500rpm. I checked the voltage on the tps sensor and at closed it reads .45, WOT its only at 3.6 volts. I also tried putting my finger on the this hole and it idled perfectly fine. Is my tps sensor bad? Or what is the problem.
Old Jun 24, 2006 | 12:24 PM
Hawkze_2.3's Avatar
Default Re: High Idle!! (Linh.)
I haven't dealt with S2 throttle bodys, but where does that hole go?
Old Jun 24, 2006 | 12:30 PM
Linh.'s Avatar
Default Re: High Idle!! (Hawkze_2.3)
I'm not even sure were that hole goes to.
Old Jun 24, 2006 | 12:32 PM
Hawkze_2.3's Avatar
Well, check it out...it probably goes to something that's not hooked up (FITV for example) and it's causing a vacuum leak.
Old Jun 24, 2006 | 12:39 PM
Linh.'s Avatar
If it was causing a vacuum leak how fix it?
Old Jun 24, 2006 | 12:45 PM
Hawkze_2.3's Avatar
Just find out where it goes and plug it up.
Old Jun 24, 2006 | 12:58 PM
Linh.'s Avatar
Well... there arent any vacuum lines hooked up to the throttle body just the map sensor.
Old Jun 24, 2006 | 01:00 PM
Hawkze_2.3's Avatar
What I'm saying is find out where that hole goes to and plug it up....that's what I would do.
Old Jun 24, 2006 | 02:48 PM
Linh.'s Avatar
but for more opinions..
Old Jun 24, 2006 | 03:31 PM
Linh.'s Avatar
well that hole leads to the idle screw tried adjusting but still nothing I m just go ahead and change out the tps sensor
Old Jun 24, 2006 | 10:29 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
how about you lines to the intake manifold???
Old Jun 25, 2006 | 05:02 AM
TheAccordGuy's Avatar
would a exhaust leak cause a high idle as well
Old Jun 25, 2006 | 05:03 AM
Default Re: (TheAccordGuy)
no...un pluggeed vacume lines will
Old Jun 25, 2006 | 03:35 PM
Linh.'s Avatar
Default Re: (I got the CD5 Jeebies!)
There aren't any unplugged lines from the manifold I replaced them and still same. Is there a way I could check to see if the IACV is still good?
Old Jun 25, 2006 | 03:54 PM
Default Re: (Linh.)
bah I don't know why I forgot to ask this earlier..what year H22 is it???
Old Jun 25, 2006 | 05:43 PM
Linh.'s Avatar
92 h22a
Old Jul 2, 2006 | 07:05 PM
Default Re: (Linh.)
Well since it's an 92 it ahs the same plunger screw t oadjust the idle...since you already did this...the only thing I can think of is to put the stock TB back on and see if that solves the problem...I'm kinda stumped too???
Old Jul 3, 2006 | 10:36 AM
hp92lude's Avatar
Default Re:
i have this similar problem on my prelude and rather than creat another thread im posting in this one.
i got a 92 S with JDM H22A, (stock jdm h22 throttle body) i/h/e, throttle body spacer, throttle body coolant bypass (http://www.92lude.com/coolant_bypass.htm). my idle has been normal (700-800) since day 1 of the swap (1 year ago) until my throttle body got gunked up and we pulled it and cleaned it the day we put in the spacer. its still been normal since then though. yesterday out of nowhere i start my car and drive around (everything is normal) and stop at a light and its idling at 1500! i have no idea what to think since its been fine all this time until just now. i checked the throttle cable thinking it was to tight but it actually had slack in it.
sorry to steal the thread from you Linh. but i need to know too and didnt want flamed for making a new thread.
Old Jul 3, 2006 | 10:40 AM
Hawkze_2.3's Avatar
Default Re: Re: (hp92lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hp92lude &raquo;</TD></TR><TR><TD CLASS="quote"> throttle body spacer</TD></TR></TABLE>
The first thing to do is take that POS out and throw it away.
Old Jul 3, 2006 | 04:48 PM
Linh.'s Avatar
Default Re: Re: (Hawkze_2.3)
its all good as long as its the same topic.
Old Jul 3, 2006 | 09:08 PM
hp92lude's Avatar
Default Re: Re: (Linh.)
ok so i figured mine out, it was just a rubber cap that came off one of the vaccum inlets on the intake mainfold. im good to go now. good luck linh
elli
Jun 1, 2010 01:22 PM
unrealgtx
Sep 18, 2007 08:08 PM
94Integra_Ls
Feb 14, 2007 10:01 PM
I Like Hondas
Jun 11, 2006 05:35 PM
CRX_Control
Dec 30, 2004 11:03 AM
