Running lean?
Old Jun 22, 2006 | 10:52 AM
lude1888's Avatar
Default Running lean?
Lately, in the morning only, my car has a hard time starting. I usually have to give it alot of gas to get it started and it has never done this before. I took out the plugs just simply to check them and they were coated white around the node and the prongs. One of my friends keeps on insisting that I am running lean. Is there anyway to check it easily as well as change it, keeping in mind I have a dinan chipped ecu?
Old Jun 22, 2006 | 11:10 AM
lude1888's Avatar
Default Re: Running lean? (lude1888)
I was also wondering could I simply just reset my ecu?
Old Jun 22, 2006 | 12:58 PM
lude1888's Avatar
bump for any info
Old Jun 22, 2006 | 01:03 PM
98vtec's Avatar
moderator emeritus
there's no way besides looking at the spark plugs to diagnose running lean unless you have a wideband o2 sensor.
post a picture of your plugs maybe...?
Old Jun 22, 2006 | 01:41 PM
lude1888's Avatar
Default Re: Running lean? (98vtec)
Old Jun 22, 2006 | 01:43 PM
98vtec's Avatar
moderator emeritus
too blurry.
use the macro button on the camera to take close pictures. It should be an icon that shows a flower depending on what camera you have.
Old Jun 22, 2006 | 01:45 PM
lude1888's Avatar
Old Jun 22, 2006 | 04:38 PM
gooseman's Avatar
that looks normal, but you should try ngk's instead of those bosche's.
Old Jun 22, 2006 | 04:44 PM
fastlude69's Avatar
Default Re: Running lean? (gooseman)
fours suck never run them on a honda always have had bad experences with them. run like single prong
Old Jun 23, 2006 | 03:19 PM
lude1888's Avatar
Default Re: Running lean? (fastlude69)
yeah I will I just did it to settle a bet and now I won a pack of 4 ngk iridium IX's. I think these ought to do it.
BoldFart16
Jul 4, 2011 11:51 AM
corkss
May 9, 2009 03:49 AM
Revi
Oct 28, 2006 09:52 AM
yz125rider21
Jan 17, 2006 03:54 PM
bronzehatch
Jul 22, 2002 02:14 PM
