can't pull codes?
Old Jun 21, 2006 | 03:13 PM
iwubmybb4's Avatar
Default can't pull codes?
well.. i put a prong into the jumper wire and my codes wont come up! how can i check my codes.. i also took it to a mechanic and he tried to jump it from the ecu.. still nothing.. i was throwing codes with my p13 before and he couldn't check it.. so now i'm running a chipped p28 and the car is running better... but once in a while it'll throw a code... why can't i check my codes? any help will be very helpful. thank you.
Old Jun 21, 2006 | 07:57 PM
dreams190's Avatar
If the CEL just stays on and doesn't flash a code, that means that your ECU isn't getting power. Check all the wiring back to the fuse box, check your fuses, you should find something wrong there.
RiipTiide67
Engine Management and Tuning
Jan 16, 2012 06:57 AM
1sikhatch
Jan 31, 2010 09:06 AM
See Are X
Jul 13, 2003 09:26 PM
MeanGreenEG9
Dec 4, 2002 07:58 AM
BoostedGSRBubble
May 10, 2002 08:40 AM
