4WS Problems With yellow top?
Old Jul 28, 2006 | 08:02 PM
DC5 Demon's Avatar
Default 4WS Problems With yellow top?
Has anyone heard of Optima Yellow top messing with 4WS? I dont have naother battery to try but pretty much after i installed my Optima my 4WS went o the fritz and when i was going around a turn it gave out on me..lets jut say i don't like drifting like that thank god i missed the pole and just went threw a field at 65MPH.....i will let you all know what i find out.
Old Jul 28, 2006 | 08:23 PM
shutta's Avatar
ok, a battery is definatly not going to mess up yoru 4ws. do your rear wheels not lock up when the 4ws throws a code? never heard of anyone having that problem.. i'm definatly interested in hearing what happened. did you get towed or did the 4ws get back into position? i definatly want to know the specifics of what happened (being a fellow 4ws owner)
Old Jul 29, 2006 | 06:59 AM
DC5 Demon's Avatar
Default Re: (shutta)
See thats what I don't get when i go around a turn with a code thrown it seems to give out literally like the rear end basicly feel like it drifts about 2-3" and when your moving 45mph and above, that will scare the **** out of you. Here is why i have the theory on the battery. When i got my car back in january it ran fine not codes etc for about a month, right about the same time i had installed my stereo system and battery. To make a long story short when the car had set all night in the cold weather 4WS would work fine but once i drove it somewhere and turned the car off the 4WS light would come on, on the next start. as it started getting warmer out i noticed 4WS working alot less. So the battery/voltage theory came into play b/c when its cold outside your battery voltage drops but after you drive it that would mean it was recharged and up to really good voltage. could be a shitty theory i know buy when i bought the car the 4WS worked fine, put system in 4ws stopped working. Then in january i put another motor in ran it w/o the system for a month and like i stated before as soon as the system/battery went in it started messing up. Also the system is out now so all i have left is to swap the battery today and i will let you know how that goes ........
Old Jul 29, 2006 | 11:11 AM
Giant_Bean's Avatar
Default Re: (92JDMH22Prelude)
sounds to me like your having an issue with the solder joints on the 4ws ecu
Old Jul 29, 2006 | 12:06 PM
VtecFreePrelude's Avatar
you do only have 1 battery right?
not running 2 for a system are you
Old Jul 29, 2006 | 01:44 PM
AndyD's Avatar
Default Re: (Giant_Bean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutta &raquo;</TD></TR><TR><TD CLASS="quote">ok, a battery is definatly not going to mess up yoru 4ws. do your rear wheels not lock up when the 4ws throws a code? never heard of anyone having that problem.. i'm definatly interested in hearing what happened. did you get towed or did the 4ws get back into position? i definatly want to know the specifics of what happened (being a fellow 4ws owner)</TD></TR></TABLE>
Many of us have an issue with our rear wheels not locking when the 4WS system throws a code and shuts down.
I doubt the battery has anything to do with it, but just try another battery to see if it changes anything. You never know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Giant_Bean &raquo;</TD></TR><TR><TD CLASS="quote">sounds to me like your having an issue with the solder joints on the 4ws ecu</TD></TR></TABLE>
DO NOT drive your car fast or make any sharp tunrs while the 4WS light comes on. I drive my car with A LOT of caution when the 4WS light come son. I don't drive over 60mph either. The rear of the car is too unstable.
Old Aug 1, 2006 | 12:29 PM
DC5 Demon's Avatar
Default Re: (AndyD)
Well i replace the battery, nothing happened, light came back on so that theory is out the window. Does anyone have the link to 4WS codes i don't have a manual yet so im sorts SOL. I also checked all the wires running into the ECU in the back and nothing was lose there.....
Old Aug 1, 2006 | 01:45 PM
Chuckles99SH's Avatar
Like one of the posts above said, check the soder points for the 4ws ECU, I think there is a write up somewhere if you search..
CodyD47
Honda Civic (2006 - 2015)
Mar 30, 2014 12:09 PM
Tom's hybrid
Honda Civic (2001 - 2005)
Jan 7, 2013 04:02 PM
daver321
Dec 25, 2008 06:39 AM
corrobjake
Apr 18, 2008 07:20 AM
