installing engine!
Old Jul 31, 2006 | 09:13 PM
MadCityLude
Guest
Posts: n/a
Default installing engine!
Well I just completed a mild rebuild and am kind of up in the air about what I should do for my harness. The guy who helped my do the swap originally modified my f22 harness for my H22. But IMO he did a hack job. I really wanna clean it up so should I try to fix this harness or start fresh.
I would like to just buy an H22 harness but can't seem to find one anywhere. Are they pretty tought to find? If so should I maybe get another F22 or H23 and start over with it?
By the way this is for an ODB1 setup.
Thanks
Old Jul 31, 2006 | 10:28 PM
JasonST's Avatar
Default Re: installing engine! (MadCityLude)
I'd look on ebay, there's one right here. http://cgi.ebay.com/ebaymotors...ZWDVW
Also u could try posting here on H-T. Also just try searching for one thats for sale.
Old Jul 31, 2006 | 10:57 PM
MadCityLude
Guest
Posts: n/a
Default Re: installing engine! (JasonST)
I searched all over HT. Never thought to look on ebay though. That is for a 96 accord. It is prolly for an F22 I would prefer an H22 if that is what I need to do. Thanks though.
Modified by MadCityLude at 2:20 AM 8/1/2006
Old Aug 1, 2006 | 02:54 AM
pentaq's Avatar
The only difference between these harnesses is the lack of a few sensors (IAB, KS, VTEC if non VTEC F22) and maybe the length of wires maybe not sufficient to plug the existing sensors. But it's not the problem.
Old Aug 1, 2006 | 07:08 AM
MadCityLude
Guest
Posts: n/a
Default Re: installing engine! (pentaq)
Do you think I can fix his hack job without hurting the integrity of the harness?
Or do you think it would be easier and better to start over?
Old Aug 1, 2006 | 07:12 AM
Pullig's Avatar
i have an h23 auto harness sittin here at my house if your interested. i believe you would have to wire in vtec solenoid and pressure sensor.
Old Aug 1, 2006 | 07:51 AM
ChrisRicketts's Avatar
Default Re: installing engine! (Pullig)
i vouch for pullig^^
well, if you've really got the cash and want it to look super nice, you could always just get one from the dealer.......but if i remember correctly you'll end up paying around 700 bucks or so for it.
Old Aug 1, 2006 | 07:57 AM
jdmlude_dude's Avatar
Default Re: installing engine! (ChrisRicketts)
what model car is this going in to?
Old Aug 1, 2006 | 09:04 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisRicketts &raquo;</TD></TR><TR><TD CLASS="quote">i vouch for pullig^^
well, if you've really got the cash and want it to look super nice, you could always just get one from the dealer.......but if i remember correctly you'll end up paying around 700 bucks or so for it.</TD></TR></TABLE>
Yep, just use an h23 harness and wire vtec in
Old Aug 1, 2006 | 09:23 AM
MadCityLude
Guest
Posts: n/a
Default Re: installing engine! (jdmlude_dude)
If I did have $700 I wouldn't be spending it on a harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude_dude &raquo;</TD></TR><TR><TD CLASS="quote">what model car is this going in to?</TD></TR></TABLE>
92 Honda Prelude S - The swap was already in the car, but the wireing is crap. Very messy! It was the F22 harness modified to work on the H22. I am just wanting to clean it up.
Old Aug 1, 2006 | 09:44 AM
marks_lude's Avatar
ive seen some bad stuff happen when ppl try to mod a Fseries harness for an h22. if u can get an h23 harness, it would just take two wires to the ecu to get it perfect (also another wire from the engine to some ground as well)
you may need the chassis side of the harness as well to do this but im not sure.
Old Aug 1, 2006 | 11:12 AM
MadCityLude
Guest
Posts: n/a
Default Re: installing engine! (marks_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marks_lude &raquo;</TD></TR><TR><TD CLASS="quote">
you may need the chassis side of the harness as well to do this but im not sure.</TD></TR></TABLE>
Can anyone verify this? I have my stock ecu to firewall harness from the original F22. Is it the same as the H23 models?
Old Aug 1, 2006 | 08:31 PM
LudeBehavi0r's Avatar
Try sending 2lude4u a Pm, he might have some 'ish.
Old Aug 2, 2006 | 07:21 AM
Default Re: (Ludebehavior85)
i just finished this swap...i used an h23 harness and pinned vtec..worked fine w/ p13. thru a map sensor code though. unsure of this...i am working to figure that one out.
Old Aug 2, 2006 | 07:22 AM
Default Re: (jdmlude_dude)
you dont have to change out anything special...on the prelude s...just get the h23 harness and pin vtec
Old Aug 2, 2006 | 07:32 AM
MadCityLude
Guest
Posts: n/a
so the H23 engine harness will plug directly into my F22 ecu-firewall harness?
Old Aug 2, 2006 | 07:36 AM
Default Re: (MadCityLude)
this is correct
Old Aug 2, 2006 | 07:39 AM
MadCityLude
Guest
Posts: n/a
thank you
Old Aug 2, 2006 | 07:35 PM
no prob
mike541
Apr 13, 2011 01:40 PM
MadCityLude
Aug 17, 2006 10:17 AM
3.point.2
Aug 7, 2004 03:29 PM
OutlawCL
Jul 29, 2004 08:40 PM
