spark plug replacement
Old Aug 1, 2006 | 11:33 AM
syshs's Avatar
Default spark plug replacement
I want to put new spark plugs and spark plug wires in my 1999 prelude.
1. is there anything else i should be replacing with that?
2. where are the spark plugs located under my hood?
3. does anybody have a DIY for it?
Thanks.
Old Aug 1, 2006 | 11:37 AM
prelude1897's Avatar
Default Re: spark plug replacement (Yash)
should replace the cap and rotor as well. You don't have to, but it would be a good idea to since the parts are cheap anyways
1) Pop your hood
2) Take plug cover off (4) 10mm bolts
3) Take plug wires out of each hole
4) Use Spark plug removal socket to take each plug out
5) Do all these steps in reverse, but take the little rubber thing out of the spark plug socket so that the socket doesn't get stuck on the plugs when putting them back in
Old Aug 1, 2006 | 11:43 AM
syshs's Avatar
Default Re: spark plug replacement (prelude1897)
Hey, you are located in Dallas, right? Me too.
You seem like a pro when it comes to talking about 5th gen preludes.
I have more questions for you, if you dont mind.
Old Aug 1, 2006 | 11:47 AM
specbb6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">should replace the cap and rotor as well. You don't have to, but it would be a good idea to since the parts are cheap anyways
1) Pop your hood
5) Do all these steps in reverse, but take the little rubber thing out of the spark plug socket so that the socket doesn't get stuck on the plugs when putting them back in</TD></TR></TABLE>
NGK spark/wires FTW!
Old Aug 1, 2006 | 11:48 AM
syshs's Avatar
Okay here is the question...
I have a clicking noise coming from the rear passenger side, when I take turns.
Im not sure if it my axle, suspension, wheel bearing, or something else???
I showed it to a mechanic. The mechanic, did a road test with me driving and he sitting in the passenger seat. He said, its coming from the rear, from both the coilovers. He said thats normal for aftermarket coilovers to make that noise. He said, its not the axle as when the axle goes bad, the noise is loader and doesnt come from the rear.
Also, I have been hearing this noise, since maybe November 2005, when I had got my new coilovers. I was just avoiding it, since I was busy with work, but I have time now to look into it.
If it were my axle, I guess it would have been broken by now.
Right?
Old Aug 1, 2006 | 11:54 AM
specbb6's Avatar
is it only when you take turns, or when you go over bumps? my prelude does it too, you can fix by replacing the shock collar (TSB 00-090) its like 10 bucks at honda. pretty easy to install too.
Old Aug 1, 2006 | 11:57 AM
syshs's Avatar
Default Re: spark plug replacement (specbb6)
i THINK, its on bumps too and i THINK sometimes when my car is rolling backwards.
So, what is a shock collar (TSB 00-090)?
Old Aug 1, 2006 | 12:04 PM
specbb6's Avatar
The collar is located at the top of the rear struts, under the upper bushing. To be able to see it you must first remove the top nut and washer from the rear strut.
Modified by specbb6 at 3:26 PM 8/1/2006
Old Aug 1, 2006 | 12:11 PM
petern101's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yash &raquo;</TD></TR><TR><TD CLASS="quote">Hey, you are located in Dallas, right? Me too.
I have more questions for you, if you dont mind.</TD></TR></TABLE>
i actually own him in knowledge
Old Aug 1, 2006 | 12:13 PM
syshs's Avatar
Default Re: spark plug replacement (petern101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 &raquo;</TD></TR><TR><TD CLASS="quote">i actually own him in knowledge </TD></TR></TABLE>
If so...
what do you think about my above problem about the noise on the turns?
Old Aug 1, 2006 | 12:18 PM
petern101's Avatar
^lol i'm just messing with him cause i know him
anyways, it could be your coilovers or a blown shock. sometimes it just squeeks because its aftermarket (friends 5th gen squeeks / clanks with tein flex's and the car is perfectly fine)
Old Aug 1, 2006 | 12:27 PM
LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specbb6 &raquo;</TD></TR><TR><TD CLASS="quote">is it only when you take turns, or when you go over bumps? my prelude does it too, you can fix by replacing the shock collar (TSB 00-090) its like 10 bucks at honda. pretty easy to install too.</TD></TR></TABLE>
+1..It's defenitly not normal for coilovers to make a clicking noise. Mine have never made a clicking noise ever since I installed them over 2 years ago
Old Aug 1, 2006 | 12:30 PM
syshs's Avatar
Y'all seem to know each other and are from DF-Dub. Me too. I have 5th gen prelude and Im a noob when it comes to car-talk.
Thanks for your help. So, would you say its something I shouldnt be worried about at all or should I get both the rear shock collers replaced?
Where do yall go for tune ups in dallas. Im in north dallas area, close to the tollway.
Is Matchless-Performace in Carrolton any good?
Old Aug 1, 2006 | 12:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yash &raquo;</TD></TR><TR><TD CLASS="quote">Y'all seem to know each other and are from DF-Dub. Me too. I have 5th gen prelude and Im a noob when it comes to car-talk.
Is Matchless-Performace in Carrolton any good?</TD></TR></TABLE>
I do all my tune-ups at my house I haven't taken my car to a mechanic ever since I've boughten it. The NTPOG people always help each other out
Old Aug 1, 2006 | 12:35 PM
syshs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">I do all my tune-ups at my house I haven't taken my car to a mechanic ever since I've boughten it. The NTPOG people always help each other out </TD></TR></TABLE>
Cool...
I will be coming over this Sunday, definately. I look forward to seeing you guys and getting some knowledge from yall pros.
Old Aug 1, 2006 | 12:37 PM
We can even change out your plugs, cap, and rotor for you
Old Aug 1, 2006 | 12:39 PM
syshs's Avatar
Sweet... That would be awesome. Wow... I never thought this kinda help existed.
Old Aug 1, 2006 | 12:41 PM
specbb6's Avatar
same here.
I'll be at the meeting too.
CONTROLLED CONFUSION
Nov 8, 2007 03:23 PM
Doeboy
Dec 21, 2004 03:26 PM
5lugSlug
Jul 19, 2004 07:34 PM
HatchBox
Sep 6, 2002 05:12 PM
