Code 43, please help
Old Jul 29, 2006 | 04:42 PM
chief vtec's Avatar
Default Code 43, please help
I have a 95 H22 and its throwing a code 43 (Fuel Supply System) I think I understand that this includes Fuel pump, filters, and injectors. My question is what to do about this? Has anyone had the same issue? Can the dealership diagnose the exact problem? Should I try replacing anything myself (I have medium mechanical skills)?
MOST IMPORTANT. Can I drive this (gently, short distances) without doing more damage, or should I not drive it at all until fixed?
Thanks in advance
Old Jul 29, 2006 | 04:59 PM
BluLude's Avatar
Default Re: Code 43, please help (chief vtec)
Beacuse I haven't seen your car and wut not I can't be 100% sure, but I am 99% sure its the 02 sensor, the dealership can diagnose the exact problem and so would any other repair shops, replacing 02 sensors should be preety simple as long as you dont run into any problems and have the right tools, and lastly, yes you can drive it short distances
Good Luck
Ray
Old Jul 30, 2006 | 05:22 AM
Duane_in_Japan's Avatar
Default Re: Code 43, please help (BluLude)
Vote up, O2 sensor, you can do it, get an OEM sensor only, pricey but good, dont put in a Bosch.
Old Jul 30, 2006 | 08:05 AM
93h22a1vtec's Avatar
Default Re: Code 43, please help (Duane_in_Japan)
tighten ur gas cap
Old Jul 30, 2006 | 12:07 PM
chief vtec's Avatar
Default Re: Code 43, please help (93h22a1vtec)
Doesn't the O2 sensor have its own code?
My gas cap is tight, but could it be something as simple as a new gas cap.
Am I O.K. to drive the car with this issue? (The car seems to be running fine)
dejay2014
Aug 24, 2014 09:16 PM
JDM_SOHC
Apr 12, 2009 02:38 PM
alberto.garrido
Jul 27, 2004 09:33 AM
DC2EGHB
13
Mar 18, 2004 05:44 AM
nutsack
Jan 21, 2002 09:41 AM
