Fuel Pump
Old Aug 2, 2006 | 01:12 PM
indra_92prelude's Avatar
Default Fuel Pump
My car is having problems, sometimes it won't crank. We know it is probably the fuel pump or the main relay, can someone help me and direct me the right way! Thank you
Old Aug 2, 2006 | 03:04 PM
prelude1897's Avatar
Default Re: Fuel Pump (indra_92prelude)
possibly ignition switch or main relay
Old Aug 2, 2006 | 05:09 PM
ViZ's Avatar
ViZ
Is the engine turning over with the starter and just not starting or is it turning over slowly or just clicking.
If its turning slow or not at all then its going to be a starter, battery, charging or control circuit issue.
Please clarify.
Old Aug 2, 2006 | 05:14 PM
SKDRCR's Avatar
Default Re: (ViZ)
It will still crank if the main relay or fuel pump is bad.
Old Aug 2, 2006 | 11:53 PM
onefastrx7turbo's Avatar
Default Re: (SKDRCR)
^^ +1 like stated above, must be the starting system to include starter, possible clutch switch, ignition switch, starter solenoid if not cranking. If cranking and not starting, thats a whole other list.
j3wman
Nov 26, 2014 01:50 AM
ReedMann
14
Aug 19, 2013 10:23 AM
Patrick Cessnun
Feb 10, 2013 08:51 AM
acidburn2k2
Dec 10, 2009 06:25 AM
taboo948
May 19, 2008 07:26 AM
