need help bad
Old Aug 13, 2007 | 08:09 AM
dapaur's Avatar
Default need help bad
working on an h23 mechanic says there was engine sludge. Dropped oil pan looked okay, checked timing belt, checked timing. has spark and fuel no ignition. Crank moves freely. Figured a bad ring put oil pan back on go to start. Now i get a glug glug noise from oil pan and i put the compression tester on(to see if i have a bad ring) and get nothing needle doesnt move. The comp tester works put it on my car when it was reading 0 and it read fine. does anyone have an idea on where i can start. The starter works turns flywheel the crank turns but no ignition. im out of ideas on where to start now and why the comp test is reading 0.
Old Aug 13, 2007 | 06:04 PM
dapaur's Avatar
Default Re: need help bad (dapaur)
bump
Old Aug 14, 2007 | 03:18 PM
dapaur's Avatar
bump need some help bad
Old Aug 14, 2007 | 04:17 PM
Si Speed's Avatar
Check the plugs, wires, and distributor. Make sure nothing is wrong there.
Old Aug 15, 2007 | 06:21 PM
dapaur's Avatar
Default Re: (si_speed)
all the wires work plugs are fairly new and the distrubtor works all 4 wires give spark. also a friend of mine told me if one cylinder is bad the car should still run on the other 3 just rough idle i duno if this is right and other help apprectiated
Old Aug 15, 2007 | 06:25 PM
Giant_Bean's Avatar
Default Re: (dapaur)
is the reading 0 on one cylinder or all of them? and yes, even if one has no compression, it should run, poorly, but it will usually run.
Old Aug 18, 2007 | 12:17 PM
dapaur's Avatar
Default Re: (Giant_Bean)
i only ran the one cyl 4 and then i checked my car to make sure it wasnt the compression tester but by theni was so frustrated i stopped working i am going to check the rest eitehr tommrow or monday
Old Aug 23, 2007 | 02:08 PM
dapaur's Avatar
ran low comp in all 4 cyl come to conclusion that he ran to much oil and oil pressure was to high and blew all the rings in process of swapping in a new motor so any other suggestions let me know we will prably be rebuilding the origanl
Old Aug 23, 2007 | 02:41 PM
M@'s Avatar
M@
sux. I might be interested in the motor.
Old Aug 24, 2007 | 02:06 PM
dapaur's Avatar
Default Re: need help bad (M@)
let me know before he starts buying the parts to fix it if you need anything else off the prelude
fitbkeco
10
Mar 2, 2013 02:15 AM
gsrboost737
Apr 16, 2009 11:38 PM
r1ch1e
21
Oct 20, 2007 07:10 AM
freshjdm
Aug 7, 2007 12:53 PM
smallsvw
Jan 31, 2004 03:50 PM
