ABS Code
Old Aug 11, 2007 | 04:42 PM
LukieLuc's Avatar
Default ABS Code
3 Fast-short pause- Then 4 Fast Then reapts What is this code for??
Old Aug 11, 2007 | 04:44 PM
Mike1995HondaPrelude's Avatar
Default Re: ABS Code (LukieLuc)
sorry, i can't help you. But, maybe you can help me. Where do I jump the OBD1? Where is it? Thanks
Old Aug 11, 2007 | 04:52 PM
nemesis25's Avatar
If the car is 1998 and later, it may be code 34 which is left front outlet solenoid. If, the car is 1997 and earlier it maybe the Right and Left rear pulsers.
Old Aug 11, 2007 | 04:57 PM
Default Re: (nemesis25)
How do I get to the OBD1 in a 1995 prelude? Thanks
Old Aug 11, 2007 | 05:04 PM
dagle's Avatar
Default Re: (Mike1995HondaPrelude)
uhh i have a OBDII 5th gen, but i believe for 4th gen its on the driver side near the pedals. theres a kick panel there?
Old Aug 11, 2007 | 05:20 PM
Default Re: (dagle)
i believe so..
Old Aug 11, 2007 | 05:22 PM
LukieLuc's Avatar
Default Re: (dagle)
its under the radio near where your right foot sits, its a blue plug
LukieLuc's Avatar
Default Re: (LukieLuc)
\<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">3 Fast-short pause- Then 4 Fast Then reapts What is this code for??</TD></TR></TABLE>????????????????????????????????????????
Old Aug 11, 2007 | 05:37 PM
so.. to jumper it i need to get a wire from autozone or something? Thanks
Old Aug 11, 2007 | 07:41 PM
LukieLuc's Avatar
no anthing that can conduct elect..... like paper clip, or any wire
Old Aug 11, 2007 | 08:41 PM
LukieLuc's Avatar
Old Aug 11, 2007 | 09:08 PM
LukieLuc's Avatar
got it
https://honda-tech.com/zerothread?id=1361638
got this code * Main Code 3, Sub Code 4 - Right Rear, Left Rear Pulsar.
How do i fix this?
Old Aug 12, 2007 | 12:56 PM
LukieLuc's Avatar
Up
Old Aug 12, 2007 | 09:28 PM
LukieLuc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">got it
How do i fix this?</TD></TR></TABLE>
Old Aug 13, 2007 | 05:13 PM
LukieLuc's Avatar
up????
Old Aug 13, 2007 | 08:09 PM
LukieLuc's Avatar
got it
How do i fix this?
Old Aug 14, 2007 | 08:46 AM
LukieLuc's Avatar
got it
How do i fix this?
Old Aug 22, 2007 | 09:32 PM
LukieLuc's Avatar
up, need answers
Old Aug 23, 2007 | 09:10 AM
LukieLuc's Avatar
Old Aug 23, 2007 | 09:14 AM
mgags7's Avatar
I'm pretty sure that means that the pulsar is the hall effect ring on the axles up front and the hubs in the rear.
I would make sure they're there and that the sensors look ok and are well plugged in, maybe try replacing a sensor.
serjey15
Feb 6, 2011 08:11 PM
paniaguae640
May 27, 2008 01:42 PM
bboy6
Jul 26, 2004 03:30 PM
H22A EG6
Dec 22, 2003 01:21 PM
