engine code
Old Aug 10, 2007 | 02:12 PM
integ_lude's Avatar
Default engine code
I could not find this on the site so I am posting it. I have an engine light come on my car and its a single flash when I turn the key on and then it stays solid. I have a 98 honda prelude standard. My oil is good, antifreeze, all other fluids. What could this be? My car is running great, I did change my spark plugs and distributor cap recently and they are NGK so they should be pre-gapped.
Thanks
-Logan
Old Aug 10, 2007 | 02:36 PM
bluedlude's Avatar
Default Re: engine code (integ_lude)
you have to get the code checked. most auto parts stores do it.
Old Aug 14, 2007 | 04:52 AM
integ_lude's Avatar
Default Re: engine code (bluedlude)
k thanks man,
-Logan
Old Aug 16, 2007 | 05:05 AM
integ_lude's Avatar
I researched and found out not using premium gas could pop up the check engine light, I only used mid grade two times and the engine light came on. When I got home I filled up with premium and fuel management filler. I reset my battery and have been running the car for about 20 miles now with no check engine light on. I guess honda's are picky about their octane.
Thanks guys!
Old Aug 16, 2007 | 05:25 AM
bluedlude's Avatar
well im glad it was that easy. your fuel door does say premium only.
Old Aug 16, 2007 | 06:56 AM
integ_lude's Avatar
That is true but I guess my mind says "im cheap". Now I learned my lesson, don't cheap out on everything.
Joshboom2488
11
Jul 27, 2014 05:50 AM
pindented
Jul 11, 2013 11:07 AM
EK VTi
Apr 21, 2009 12:45 PM
si937
May 7, 2008 11:18 PM
Prelude MIke
Mar 28, 2004 09:49 PM
