Automatic Shifter (brake?) problem
Old Aug 12, 2007 | 02:40 PM
Entaka's Avatar
Default Automatic Shifter (brake?) problem
When I push the brake in it does not release the shifter. To put the car into any gear I have to use the emergency *keyhole* shift. I was wondering if there is a fuse, relay, or anything else that would make this not work. I have tried 2 different switches at the brake side and 3 different switches at the shifter side and all combonations of them and nothing has worked. Any one have any ideas?
Old Aug 12, 2007 | 04:14 PM
marcs1337's Avatar
Default Re: Automatic Shifter (brake?) problem (Entaka)
do your brake lights work? if they dont, its most likely the brake switch
Old Aug 12, 2007 | 05:04 PM
royalfelix's Avatar
Default Re: Automatic Shifter (marcs1337)
well by any chance did u mess with your tps sensor? when i installed mine once i guess i installed it to advanced or something and it wouldnt let me put the car in gear nither and i guess if your brakes light arent working then that sensor is damaged which i guess is the same switch that controls the shift release
Old Aug 12, 2007 | 05:25 PM
Entaka's Avatar
Default Re: Automatic Shifter (royalfelix)
Brake lights work OK. I was checking under the dash to see what else the wires plug into and it looks like a few of the wires off the brake switch go into a redish orange box. Looked on my JDM front clip and cant find it on the drivers side at least.
Old Aug 13, 2007 | 07:42 AM
JasonST's Avatar
Default Re: Automatic Shifter (Entaka)
When u press the brake down it should release a lock near the shifter, underneath the center console, take the plastic center console pieces apart and u should be able to see it, it's a plastic lock that's suppose to release when the brake is pushed, once u find it u can unlock it manually.
Old Aug 17, 2007 | 10:03 PM
Entaka's Avatar
Default Re: Automatic Shifter (JasonST)
Yeah Ive had the center console off for that reason. Im trying to find a fix so I can put the console back in and have it functioning as it should. Any one have any more thoughts as per why the brake lights would work and the shift release wouldnt?
thrasherx
Jun 23, 2024 04:22 AM
oohtruck
Sep 17, 2012 08:46 AM
standbackimapro
Jan 27, 2006 06:07 AM
drunkinmiami
Nov 19, 2005 12:52 PM
puppetmstr80
Aug 26, 2005 11:43 PM
