how do you pull the abs light code ?
Old Aug 10, 2007 | 08:22 PM
Tip14's Avatar
Default how do you pull the abs light code ?
I was wondering how to pull the abs code on a 93 prelude. The light comes on after about ten seconds of driving and when I shut it of its gone so the car isnt giving me a hard code just a temporay one.
I searched and the Integra forum gave the directions on how to pull the code on 94 and newr tegs. But it didnt say if it works with a 93 prelude.
Old Aug 10, 2007 | 08:33 PM
m00nr0ck Si's Avatar
Default Re: how do you pull the abs light code ? (Tip14)
there is a plug behind your console ...directly below your radio...just jumper it out with a piece of wire and turn the key to the on position. The ABS light will flash a series of slow blinks and then fast ...Im guessing its going to be " Pump motor overrun"
Old Aug 10, 2007 | 08:36 PM
Tip14's Avatar
But the light dosent turn on immediatly when its started do I need to drive it until it lights up then jumper will that work
Also what part does the pump over run involve
Old Aug 10, 2007 | 10:36 PM
prelude_93vtec's Avatar
Default Re: (Tip14)
ya i got the same problem. the light comes on when i start moving. i checked the code and it came to be 4-4 right rear wheel speen sensor. you proly haeve the same problem. although my speedo still works
Old Aug 11, 2007 | 03:30 AM
Default Re: (Tip14)
If the check engine or ABS light comes on at any time , even for a split second and then goes out , the ecu stores those codes in memory until you reset the ecu ...
Old Aug 11, 2007 | 08:10 PM
Tip14's Avatar
Okay today I pulled the code and it was code 1 Abs pump over run what does that mean and what part is going bad anybody know ?
Old Aug 11, 2007 | 08:14 PM
LukieLuc's Avatar
Default Re: (Tip14)
where did you get the code list for the ABS? i got 3fast blanks a short pause than 4fast blanks
What does that mean?
Old Aug 11, 2007 | 08:25 PM
Tip14's Avatar
Use the search and type in abs codes and a list should come up
Old Aug 12, 2007 | 08:44 PM
Tip14's Avatar
bump...
Anyone know what this means or what part is bad ?
* Main Code 1 - Pump Motor Over-Run. Pressure Switch.
Old Aug 23, 2007 | 04:58 PM
jdmlude5
Guest
Posts: n/a
Default Re: (Tip14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tip14 &raquo;</TD></TR><TR><TD CLASS="quote">bump...
* Main Code 1 - Pump Motor Over-Run. Pressure Switch.</TD></TR></TABLE>
i have the same code friend that works at honda said the whole pump is bad.
DoHcV-tEc
Feb 25, 2008 10:30 PM
mt23vtecbb2
Jul 18, 2005 08:54 AM
TheOne
Apr 4, 2003 06:41 AM
Havokgsr
Oct 1, 2002 03:25 PM
