**** EuroR Dyno Testing Results***** good stuff
Old 08-08-2007, 04:50 PM
moderator emeritus
98vtec's Avatar
Default **** EuroR Dyno Testing Results***** good stuff
ok well it was even hotter tonight than it was with the OEM runs, but that doesnt even make a difference at this point. The manifold simply picked up power in every way except at the vtec crossover. I'll let the graphs do the talking. with a CAI i see this making mid 190 whp and high 150's in torque. I got a friend of mine that is giving me his interfooler intake system. not gonna be using the filter part but ima see what i can do with the piping.
I also found out that my wideband is reading completely wrong, that 149whp run told that story. My wideband was reading 12-13 AFR and the dyno was reading 15's in vtec!!! gotta get that fixed asap.
The above graphs display my base runs for each manifold and the best runs for each.
this graph shows the difference between the OEM ported IM's best versus the EuroR's best.
And remember that my intake setup is far from being the most powerful. This test has just about convinced me that i'm not sending the manifold back and i'll be paying for it
This manifold can be purchased from http://www.roskoracing.com aka Rosko. It includes everything to make this manifold a direct bolt on.
EDIT:
Tom's Test. Dyno run without vtec:
MY SETUP:
JDM H22a
super short ram with BPI flowstack
Gen1 RMF narrow
2.5" carsound cat
2.25" exhaust
s2000 throttle body
splitfire plugs
NGK wires
PS, AC removed
EuroR IM
p28 / NepTune RTP
Modified by 98vtec at 8:18 PM 8/8/2007
Modified by 98vtec at 9:23 PM 8/8/2007
Modified by 98vtec at 10:55 PM 8/8/2007
Modified by 98vtec at 11:00 PM 8/8/2007
Modified by 98vtec at 12:34 AM 8/9/2007
Modified by 98vtec at 10:07 PM 8/14/2007
98vtec is offline
Old 08-08-2007, 05:10 PM
gogunkergorilla's Avatar
Default Re: **** EuroR Dyno Testing Results***** good stuff (98vtec)
did you mess with vtec at all???what ems are you running???
gogunkergorilla is offline
Old 08-08-2007, 05:13 PM
moderator emeritus
98vtec's Avatar
Default Re: **** EuroR Dyno Testing Results***** good stuff (gogunkergorilla)
vtec is the same on both manifolds. i tried 4800, 4850, 4900, 4950, 5000 and 5100. It liked 4900 the best which just happened to be the same on both manifolds.
I'm using Neptune RTP
98vtec is offline
Old 08-08-2007, 05:17 PM
4bidden's Avatar
Always nice to gain power and not have to sacrifice it anywhere else. Nice job.
4bidden is offline
moderator emeritus
98vtec's Avatar
oh ****, i also have tom's test to post....its pretty funny
i'll be adding that in a couple minutes
98vtec is offline
Old 08-08-2007, 05:31 PM
Go Tigers!
Bense's Avatar
badass
Bense is offline
Old 08-08-2007, 05:36 PM
moderator emeritus
98vtec's Avatar
time to get the other intake, replace my axles and head back to the track
98vtec is offline
Old 08-08-2007, 05:45 PM
GoldLudeRay's Avatar
hell yes blake get too the track and brake that 13 sec time
and post a vid of course!
nice work thanks for the info
GoldLudeRay is offline
Old 08-08-2007, 05:52 PM
moderator emeritus
98vtec's Avatar
Default Re: (GoldLudeRay)
making me think more about the thread i made a long time ago about plenum volume and how me and matt were discussing how the h22 needed a smaller plenum to make some theory true. Well i think this proved that theory correct because the plenum on the euroR compared to the base h22 is TINY
98vtec is offline
Old 08-08-2007, 05:57 PM
moderator emeritus
98vtec's Avatar
Default Re: (98vtec)
https://honda-tech.com/zerothread?id=1837017
98vtec is offline
Old 08-08-2007, 05:58 PM
that reminds me blake
did you ever test the h22 im with the iab plate completely removed alltogeter, making volume smaller.
Old 08-08-2007, 06:05 PM
moderator emeritus
98vtec's Avatar
it makes the total volume smaller but doesnt decrease plenum volume. But no, i have not tested it. I was contemplating taking the EuroR off and putting my ported one on, only without the plate and heading back to spend another 100.....but honestly, i dont think it would have the gains of the EuroR.
98vtec is offline
Old 08-08-2007, 06:09 PM
i have my doughts also, the euro r graph you posted looks imprssive, i still wonder if no iab plate is better than oem.
Old 08-08-2007, 06:30 PM
SteveoBA8's Avatar
Nice!, What kind of wideband are you using?
SteveoBA8 is offline
Old 08-08-2007, 06:35 PM
moderator emeritus
98vtec's Avatar
Default Re: (SteveoBA8)
innovate LC1. i believe running around with the wideband off killed it or i am getting way wrong voltage readings
98vtec is offline
Old 08-08-2007, 07:02 PM
Rosko's Avatar
glad you got the setup to work Blake!
Rosko is offline
Old 08-08-2007, 07:04 PM
Flip.'s Avatar
Nice test.
Thanks for posting
Flip. is offline
Old 08-08-2007, 07:14 PM
moderator emeritus
98vtec's Avatar
Default Re: (Rosko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote"> glad you got the setup to work Blake!</TD></TR></TABLE>
appreciate all the work you put into these manifolds and everything you have done as a friend
98vtec is offline
Old 08-08-2007, 07:19 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">making me think more about the thread i made a long time ago about plenum volume and how me and matt were discussing how the h22 needed a smaller plenum to make some theory true. Well i think this proved that theory correct because the plenum on the euroR compared to the base h22 is TINY</TD></TR></TABLE>
werddd.
good tests dude
mgags7 is offline
Old 08-08-2007, 07:34 PM
PirateMcFred's Avatar
That's pretty neat Blake. Was that with the old RMF narrow header or what? Want to give a total setup break-down on the first post?
If nothing else it makes me want to finish my Euro-R project. You picked up about ~9% at 6500rpm. that's interesting since that's where my engine peaks...
Thanks a bunch for posting your results
Pirate
PirateMcFred is offline
Old 08-08-2007, 07:43 PM
moderator emeritus
98vtec's Avatar
Default Re: (PirateMcFred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">That's pretty neat Blake. Was that with the old RMF narrow header or what? Want to give a total setup break-down on the first post?
Pirate</TD></TR></TABLE>
yea thats with the old RMF narrow. i'll post my setup, thanks pirate.
98vtec is offline
Old 08-08-2007, 08:12 PM
A Blue Lude's Avatar
On a fully stock (emissions, sensors etc) 5g Prelude the only things you'll need to make Rosko's prepped manifold work are:
-Accord IAT sensor
-IAC Wires extended
-New coolant hoses (to reach new IAC location)
-Longer cruise control vac line, and a vac tee or two.
The stuff he makes for it is nice stuff. The 3-bolt IAC adapter is really cool
Thanks for the testing, Blake
Modified by A Blue Lude at 9:50 PM 8/8/2007
A Blue Lude is offline
Old 08-08-2007, 09:23 PM
DCxMagus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">innovate LC1. i believe running around with the wideband off killed it or i am getting way wrong voltage readings</TD></TR></TABLE>
yeah blake thats what killed my old 02, if you have the sensor in without power running to it the heater won't kick on and you'll get very false rich readings from the sensor being coated in fuel and carbon build up.
has anyone done a skunk 2 versus Euro R plot?
I was thinking of getting a skunk 2 manifold down the line but seeing 2point6 and rosko offering full bolt on euro Rs and seeing some success with the Blacktrack stage 2-3 manifolds I maybe be leaning towards them now, but thats all research for me to do on my own when the time comes to replace those parts
when did you go down to a 2.25in exhaust? I though you had a 2.5
anyway again thanks for testing and offering up the information for the community, helps everyone and shows people are still doing this to advance the hobby/sport as a whole
DCxMagus is offline
Old 08-08-2007, 09:36 PM
moderator emeritus
98vtec's Avatar
Default Re: (DCxMagus)
i have Apexi N1 piping with a vibrant streetpower muffler. N1 piping is 2.25" ID
98vtec is offline
Old 08-08-2007, 10:21 PM
M2B4's Avatar
nice. i never knew about roskos site. arg lol was gunna get car painted.....this is rly spiking my interest
M2B4 is offline
Quick Reply: **** EuroR Dyno Testing Results***** good stuff
