A/C compressor!
Old Aug 7, 2007 | 02:16 AM
hpsi93's Avatar
Default A/C compressor!
When by passing the A/C compressor, Which belt can be used to run the alternator from the crank?
Old Aug 7, 2007 | 07:44 AM
JasonST's Avatar
Default Re: A/C compressor! (hpsi93)
When I had to do this for my h22 swap, I just measured the distance between the two and the # of ribs on the alternator and crank and told it to napa and they got me a belt that'l fit. You could try the same thing.
Old Aug 7, 2007 | 11:17 AM
snowblind7x's Avatar
you can just go to kragen or autozone and get a belt for a non a/c lude
Old Aug 7, 2007 | 12:09 PM
LukieLuc's Avatar
Default Re: A/C compressor! (snowblind7x)
you need a 37" belt, i cant remember how wide
Old Aug 13, 2007 | 03:15 PM
hpsi93's Avatar
To late A/C compressor locked up and melted belt, down for a few days! Found belt at Autozone online 5 ribsx37".
Modified by hpsi93 at 8:26 PM 8/13/2007
Old Aug 13, 2007 | 04:08 PM
saikou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowblind7x &raquo;</TD></TR><TR><TD CLASS="quote">you can just go to kragen or autozone and get a belt for a non a/c lude</TD></TR></TABLE>
This is true in regards to bypassing the AC on an S/Si crank pulley. The H22 utilizes a 6 rib belt on both crank & PS pulleys.
Old Aug 26, 2007 | 02:47 AM
hpsi93's Avatar
The lude runs alot better to me, might just keep it that way!
FeelTheBass
May 15, 2014 08:59 AM
texx72
Nov 22, 2009 03:05 PM
Silvertc
Jun 18, 2008 02:02 PM
srv3fender
Mar 1, 2005 05:18 AM
NoLipRacen
Mar 13, 2004 01:01 AM
