Bleeding the coolant
Old Sep 27, 2007 | 08:13 PM
dlo102106's Avatar
Default Bleeding the coolant
Can someone please walk me through how to properly bleed the coolant in an '01 Prelude?
Old Sep 27, 2007 | 10:13 PM
preludefien
Guest
Posts: n/a
Default Re: Bleeding the coolant (dlo102106)
lol im hoping your just playing. theres whats called a bleeder screw on the bottom of the radiator and you unscrew it
Old Sep 28, 2007 | 04:58 AM
flavah0wnz's Avatar
Default Re: Bleeding the coolant (preludefien)
theres one on the thermostat housing 2
Old Sep 28, 2007 | 01:43 PM
Jagan'92's Avatar
you drain the coolant at the bottom of the radiator and refill.
if you want to bleed out the air you loosen the bleed bolt on top of the thermostat and wait until air stops coming out - meanwhile topping off the radiator.
Old Sep 28, 2007 | 03:13 PM
dlo102106's Avatar
Default Re: Bleeding the coolant (Jagan'92)
Bleeding the air was what I was looking for. Thanks.
Old Sep 28, 2007 | 03:44 PM
LukieLuc's Avatar
isnt the easy way to do it, is to leave the radiator cap off while the car warms up fully, to let all the air out the system.
Make sure the radiator fan turns on then you can put back the radiator cap
TailZ
Honda Civic (2001 - 2005)
Jun 14, 2010 10:52 AM
martiw2
Oct 26, 2008 08:10 AM
wld2rde
Feb 10, 2005 05:54 AM
Spoonvtec
Nov 23, 2003 02:16 PM
TenaciousC
Aug 22, 2002 02:11 PM
