H22A LSD Problem
Old Sep 20, 2007 | 01:17 PM
peter17212's Avatar
Default H22A LSD Problem
Hi, I just bought a LSD for my tranny and when i went to install it the LSD doesnt have the speed gear or what ever its called so i emailed back to the guy that i bought it from and he says i can buy them at any honda dealer but they dont sell them it comes in one piece with the differantial and so i cant press it off cuz its one piece........ Please help
P.S. i can go ahead and put it together but the speedometer wont work and i dont want that.....
Modified by peter17212 at 2:32 PM 9/20/2007
Modified by peter17212 at 2:37 PM 9/20/2007
Old Sep 20, 2007 | 02:35 PM
117's Avatar
117
You need the speedo gear ring for the VSS sensor.
You cannot buy the speedo gear ring from the Honda dealer. It's not available separately on the Prelude (like it is on the Civic, etc). The speedo gear ring is not machined into the stock differential. It's a press fit. Use a 3 jaw gear puller and a propane torch. Heat the gear ring up to help it expand, and use the puller to very gently pull the gear off of the differential. Don't warp it or break it since you cannot easily buy another one without buying a whole diff assembly. I've done it 5 or 6 times, and it's not bad. Just go slow, and try not to break it.
Old Sep 21, 2007 | 05:17 AM
nikolai.'s Avatar
I didn't even need a gear puller when I did mine. Just a torch. And I tapped it off really easily with a hammer and center punch. Keep the gear hot with the torch and it should slide right onto the new diff. When it cools, it will lock into place.
Old Sep 21, 2007 | 02:40 PM
B20luda's Avatar
Default Re: (nikolai.)
i used a press, its not hard to do ....
nofrenfish
Jun 25, 2014 03:32 AM
DOHCarp
Oct 21, 2010 08:59 PM
zimmy709
Jun 25, 2008 04:06 PM
drift2004
Dec 17, 2007 10:46 AM
n1_egsex
Aug 29, 2007 02:44 AM
