Final drive
Old Sep 24, 2007 | 02:48 PM
modded's Avatar
Default Final drive
Does anybody know the number of teeth on the final drives of these trannys m2b4,p2a8,h2u5.
I know most prelude and accord final drives are either 4.266 or 4.062 but I need to know the number of teeth and are they interchangable.thanks for any help.
Old Sep 24, 2007 | 06:18 PM
2point2's Avatar
Default Re: Final drive (modded)
- click the Prelude FAQ, it's at the top of the list of threads in this section.
- press CTRL+F
- search for "tranny"
you'll find a really good reference to h and f series gear ratios.
wasn't that easy?
Old Sep 24, 2007 | 07:37 PM
Silver Surfer's Avatar
Default Re: Final drive (2point2)
you're killing me
all this work i do for you and you can't spend 10secs to search for it
https://honda-tech.com/zerothread/1876526
M2B4 - JDM 4G LSD
M2B4 - 3.307 - 1.950 - 1.360 - 1.034 - 0.787 - 4.266 LSD
These 2 are not in the FAQ
P2A8 - 98-02 Accord with F23 engine
no idea on the ratios, supposed to be very long
H2U5 - 90-93 Accord with F22 engine
again don't know the ratios but can assure you they are quite long
The reason these are not published is because they are very uncommon in swaps and I am not even sure if they will work, in quick searches i have seen some say they work and some say the mounts do not line up
why do you want to include these as options with the m2b4?
I would not even consider them unless they were free and even then i would look for another low cost alternative
Oh and by the way the housings on the LSD and non-LSD trannies are different. So Final Drives between these two types would most likely not be interchangeable
Old Sep 25, 2007 | 10:35 AM
modded's Avatar
I don't know if you guys know how to read but I need to know HOW MANY TEETH ON THE FINAL DRIVE.
Old Sep 25, 2007 | 10:39 AM
mgags7's Avatar
You'll need a matching countershaft anyways, so just count both and figure the ratio out.
DIY
Old Sep 25, 2007 | 11:10 AM
Default Re: (modded)
we can all read so stop being a smart ***....
everyone who has posted in this thread more than likely has way more experience than you, so why don't you help us out and answer our questions
what you need to understand is that no one keeps records of tooth counts online
this is the best i can offer.....
Final Drive 4.0625 Non JDM
Ring = 65 teeth
Pinion = 16 teeth
Final Drive 4.2666
Ring = 64 teeth
Pinion = 15 teeth
what you need to tell us is why you need these numbers, what are you planning to do with these 3 final drives that are all from very different transmissions.......maybe we can offer some advise without having to know the exact tooth counts........since your second question was are they interchangeable.
But if you don't want our help on a very specific question then have fun tearing a tranny apart to count
Old Sep 14, 2008 | 11:57 AM
jdmaccord619's Avatar
Default p2a8
these trannys are gold i think the mounting bracket lines up fine just have to tap treads the gear are perfect if your running a real jdm h22 i belive that this tranny
is LSD both my tires light up 2nd is so sweet and 5th gear at 80 mph your sitting at abot 3,100
Old Sep 18, 2008 | 04:26 PM
carniverouspeaches's Avatar
I think what jdmaccord was trying to do was take a 5th gear out of a tranny with a 4.062 final drive and put it into a tranny with 4.26 final- so he could get a higher top end with the longer 5th.
The only question I have is this:
If I were to order a jdm h22a1 and try to bolt any regular accord tranny to it- it would fit perfectly right?
Old Dec 4, 2008 | 11:55 PM
extralargenog's Avatar
PIrate... If you have just a M2B4 ring gear layiong around can you PM me please?? Thx
I have a MIONT JDM LSD tranny that needs a new ring gear... Ima part it out if I cant find one soon. Cheap
OP:
YOU CAN intgerchange the USDM prelude counter shaft in the box with the OEM LSD DIff and ring gear
YOu are welcome.
Old Nov 19, 2012 | 04:25 PM
preludeNApower's Avatar
64 teeth
Old Nov 23, 2012 | 10:41 PM
Hidenplanvew's Avatar
I hope he figured it out 4 years later...
Old Nov 24, 2012 | 12:37 PM
98vtec's Avatar
moderator emeritus
He updated a thread with information. What did you do?
Old Nov 24, 2012 | 04:45 PM
godslayer's Avatar
He updated it with information that was already posted back in 2007 a few posts up.
Tachi
Transmission & Drivetrain
Mar 21, 2015 07:04 PM
Lil Krayzee
Jan 30, 2008 03:28 AM
NH578
Nov 29, 2006 11:14 PM
