Vtec problem!!! help
Old Sep 19, 2007 | 06:08 PM
mattm868's Avatar
Default Vtec problem!!! help
Ok so my h22a4 was rebuilt to lower the compression. So im drivin around to put 500 miles on it before theyll tune it with boost. I call of my tuner and he said slowly go throgh the rpms make sure vtec is working. When i did no vtec! Not even a change in the sound. I need some trouble shooting ideas ? Thanks
Old Sep 22, 2007 | 05:52 AM
95si_v-tec's Avatar
Default Re: Vtec problem!!! help (mattm868)
Vtec solenoid maybe??? are you just runnin the stock ecu currently?
Old Sep 22, 2007 | 06:03 AM
bluedlude's Avatar
Default Re: Vtec problem!!! help (95si_v-tec)
check the screen on the VTEC solenoid. it might be clogged up from something during the build. have you changed the oil since you started breaking it in?
Old Sep 22, 2007 | 08:11 AM
xxmastermindxx's Avatar
Default Re: Vtec problem!!! help (bluedlude)
you can also try this link from the faq's. it's to troubleshoot your vtec problem.
Old Sep 23, 2007 | 02:21 PM
mikeaitken's Avatar
Default Re: Vtec problem!!! help (xxmastermindxx)
check.
wiring.
ECU.
solenoid and its screen.
Oil pressure?
when u gnna run boost, vtec is gnna be pointless anywayz, vtec sucks more air in, just what ur turbo is gonna be doing, but a lil better. haha
Old Sep 23, 2007 | 02:23 PM
JDMgareth's Avatar
yea...wiring
no shop in my town knows how to do vtec wiring...
not sure where you live.
gsl_05
Mar 31, 2006 01:58 PM
crispydee
Sep 29, 2004 03:30 AM
b19coupe
Sep 3, 2003 07:02 PM
vspec12
Nov 5, 2001 05:25 AM
Incognito
Oct 27, 2001 10:10 PM
