Problems with starting.
Old Sep 25, 2007 | 06:32 PM
jdj316's Avatar
Default Problems with starting.
Hi,
I have a 1991 Prelude S and occassionally have problems with getting it to start. Sometimes when it is hot outside I try to start it and it struggles, but won't quite turn over. It usually then starts if I just wait for 10 minutes or so. The most frequent problem that I have with it, however, is when I turn it off and then try to start it again a short time later. It is the same problem as when it is hot outside, it struggles hard but doesn't quite turn over. I wait for 10 minutes or so and then it starts up fine. My battery and connections are brand new and it runs perfectly when it actually starts. Any suggestions?
Thanks.
Old Sep 26, 2007 | 03:58 PM
jdj316's Avatar
Default Re: Problems with starting. (jdj316)
So no one has any ideas about what could be wrong?
Old Sep 26, 2007 | 06:00 PM
Kalgorn's Avatar
What do you mean by "it struggles"? Does it slowly crank and finally fire up? Could be your starter. I had a similar issue in my Z34. Eventually, it just stopped even trying to turn over.
I don't know how being hot is affecting it though. Possibly a fuel issue? Perhaps it's not getting enough fuel to fire up until you try to crank it a few times?
Just throwing some ideas out there.
Old Sep 26, 2007 | 06:15 PM
baselude's Avatar
Default Re: Problems with starting. (Kalgorn)
need to be more specific? struggles by slow crank or by just turning over for a long time?
Old Sep 26, 2007 | 06:58 PM
jdj316's Avatar
Default Re: Problems with starting. (baselude)
It struggles by just turning over for a long time but never actually fires up. I usually just sit and wait for about 10 minutes or so and then it will usually fire up. I spoke to a guy at a repair shop and he said it could have something to do with a coil in the starter?
dustinbs144
Aug 7, 2011 08:54 PM
Joseprz
Feb 23, 2008 03:30 PM
90AcuraIntegra04
Aug 12, 2005 08:22 AM
Jet Black
Sep 10, 2003 07:07 PM
Eeepers
May 29, 2002 11:25 AM
