timing marks
Old Jan 25, 2009 | 05:12 AM
kazaa1872's Avatar
Default timing marks
i got a h22a1 i cant find my timing marks no where i checked the crankpully an i checked on the flywheeli couldnt find them no where
Old Jan 25, 2009 | 02:49 PM
Hawkze_2.3's Avatar
Default Re: timing marks
Do you not speak English as your fist language, that is horrible....
Anyway, the timing marks on on the FLYWHEEL and CAM GEARS, that is how you set timing.
Old Jan 26, 2009 | 07:51 AM
lude98SH's Avatar
there is also a mark on the oil pump, whichever you use depends on what your doing. flywheel would be used for ignition timing, oil pump and cam gears would be used to set mechanical timing.
Old Jan 26, 2009 | 11:38 AM
da9driverx's Avatar
thers arrows on the cam gears those have to be pointing up and the crank gear key lock also has to be point derictly up thats all you realy need to set your timing marks on your h22
donnjuan2point2
Mar 11, 2004 10:49 AM
Jockobo
Jan 23, 2003 03:48 PM
