HIDs help!!!!
hey. guys. after a few weeks installing my HID fogs, only one side side of my fogs light up and the other one does not turn on. I have to turn my lights off and on again ( a couple of times for it to work). i research and bought the Relay Harness to fix it. After installing the relay harness today. i thought my problem was solved but. the only thing it did was. one fog turns on while the other flickers and turns off after a few seconds. i really thought the relay would solve =/
is it the CAPACITOR that i need?????
some please help me. it has been very frustrating.
please and thank you
im pretty sure its the capacitor that i need. is there a specific capacitor that prelude uses. or a 35w HIDs uses? thanks. it would be really helpful
SCROLL down to STEP 7 and 8 for Capacitor.
http://www.lxforums.com/board/showthread.php?t=109365
This could be caused by a bad bulb, ballast or wiring. The easiest way to check this is by swapping the bulb and ballast one at a time to the side that works to check that each component is functioning as it should.
