Write up on ATTS install?
Old Jan 11, 2010 | 11:32 AM
Tunerguy1989's Avatar
Default Write up on ATTS install?
My Atts light has been on for a long time now and it acts like an open diff so i plan on replacing it with a used atts unit with only 29,000 miles on it. Does anyone have a write up on this or should i just try and use a chilton manuel(I have one and it really doesn't have any info on the atts let alone installation instuctions).
I have read about people replacing the sh tranny with a base to get rid of the atts, but would it be worth it and how exactly would the car run seeing as certain sensors would have to be removed. Would there be ECU problems.
Any help would be appreciated.
Old Jan 11, 2010 | 12:38 PM
Kronn 98SH's Avatar
Default Re: Write up on ATTS install?
Before replacing anything, I recommend following the applicable steps from the following thread. It would help you and us to know the actual problem.
https://honda-tech.com/forums/showthread.php?p=38252637
Old Jan 12, 2010 | 12:16 PM
on your write up after you figure out a code from the durations how would I know if the code is for my engine light or atts. Currently my engine light is off and only my atts is on. would that mean that the code that comes on will only be for the atts
Old Jan 12, 2010 | 12:43 PM
EGPrelude's Avatar
check below...
Old Jan 12, 2010 | 12:48 PM
Kronn 98SH's Avatar
It's based on which light is blinking. If the CEL blinks, you have a code for the CEL. If the ATTS blinks, you have a code for the ATTS. If both blink, you have a code for both.
Originally Posted by EGPrelude
Check the ATTS fuses. Usually an ATTS malfunction would trigger both the ATTS light and the CEL.
You're backwards. A CEL will cause the ATTS light to come on. An ATTS Malfunction would cause the ATTS light to come on, but not the CEL.
Old Jan 12, 2010 | 12:50 PM
EGPrelude's Avatar
^^ you sir are correct.
Old Jan 13, 2010 | 10:23 AM
RpWolfSH's Avatar
The unit may be fine but there are other sensors and such associated with the ATTS unit, so you may not have to replace it...
Old Feb 2, 2010 | 10:25 AM
Executivems's Avatar
New User
Hey everyone. Im glad you are talking about the atts. Im not as familiar with Hondas as I want to be and I am helping a freind with her prelude. She has a 91 SH and the engine light and the ATTS light is on.
First can someone quickly explain how to check and clear the codes for this car? and then what is the ATTS? Does it have to do with the transmission?
Iv been reading around on other threads but I havent been able to find one that explains anything its just a bunch of you guys that already know what all this stuff is. sorry for being a newb. Im just trying to help her out and am getting stuck.
I also dont want to look like a dumb *** because she is pretty hot.
Old Feb 2, 2010 | 10:41 AM
pheurton-skeurto's Avatar
haha! this is exactly what i was thinking when i started reading your post. it was just good to confirm that this was the case and that you were helping this chick out for the 'right' reasons.
i'm guessing that this is a typo and that you may mean 2001...there wasnt a 91 SH model prelude to my knowledge (but there is a 2001 SH with ATTS).
ATTS is a feature on the SH prelude. it applies engine torque to the wheel that 'needs it the most.' do a quick search on here and youll find a ton of info on it.
again, props for helping a hot chick out with her car. never a bad move.
Djmontiel
Feb 16, 2016 01:30 AM
blaze.1
Aug 3, 2009 10:28 AM
wreckz
Jun 26, 2005 07:46 AM
johneejumpup
Oct 29, 2004 01:49 PM
