Distibutor Problems?! help asap.
Old Jan 28, 2010 | 08:27 PM
niterider96cord's Avatar
Default Distibutor Problems?! help asap.
Alright so i recently have started playing around with installing an msd coil and cap on to my h22 on the lude (external coil stock). But have not been succesful, so wired it back up just as normal and now im getting no spark whatsoever, have checked, double checked and triple checked the wires. Any help is greatly appreciated guys.
Is it possible to fry an coil or distributor by messing with wires?
Old Jan 28, 2010 | 11:44 PM
mllude's Avatar
Default Re: Distibutor Problems?! help asap.
i would use a multimeter and check the resistance of the coil to see if its ok
Old Jan 29, 2010 | 07:47 AM
young_tuner's Avatar
Check your ignition control module inside the distributor, I tried hooking up an msd coil and had the same problem I ended up buying a new oem coil.
Old Jan 29, 2010 | 09:02 AM
How do you do that?
Old Jan 29, 2010 | 09:14 AM
LOrangeH22hatch's Avatar
search for the pdf repair manual for the car,and it will give the ICM trouble shooting procedure.
Old Jan 30, 2010 | 05:40 PM
Alright realisticly i have no problem buying a new distributor now. But will this fix the problem?? or could there be other problems?
Old Jan 30, 2010 | 06:15 PM
prelude1897's Avatar
you don't have to buy a whole new dizzy, just do what young_tuner mentioned and get a new ignition control module. You just have to take the cap off, and you'll see where a couple little wires are running. That'll be the ignition module you'll need to replace. I think there's 2 or 3 phillips little phillips head screws you'll need to take out. You can pick a new one up from Auto Zone or possibly O Riley's for around $60-$80
Old Jan 31, 2010 | 07:54 AM
street_ride14's Avatar
haha .. the curse of MSD. Now you happy ? .. THe mad scientist now has to ditch out $ 300.00 and fix the distributor you just fried. Live and learn.
Old Feb 1, 2010 | 08:04 AM
Replaced ICM still no spark... FML. They tested the old one and it failed the test but still no spark. would it may be the coil(s) as well? Hooked up the msd coil (black, yellow and black to + & Blue to -) and tryed using the stock one. Neither did the trick...
Old Feb 1, 2010 | 10:40 AM
you can test the coil and icm.
take the coil wire off of the cap and stick a spark plug in it .
lay the plug against the head or intake, make sure it has a good ground.
turn the key on so that the coil has power.
Quickly tap the icm signal wire to chassis ground and you should see a spark on the spark plug.
There is a more detailed guide for testing in the msd 6A box trouble shooting guide.
Old Feb 1, 2010 | 03:37 PM
Alright so the coil is good, had a friend at autozone that tested it in his car. *Fired right up*. So whent through him and orderd a complete dizzy. Should be in tomorrow morning. Got my fingers crossed this will finally end.. Soooo $110 for a new ICM, $40 for msd cap and rotor, and $160 for replacement (reman) dizzy, i think ive learned not to mess with ignition unless you know exactly what you are doing...
Old Feb 2, 2010 | 10:50 AM
ha ha. Sometimes we all learn the hard way. At least now you won't forget.
Old Feb 3, 2010 | 04:34 PM
Haha exactly and actually i will probably end up using the msd still anyways. and selling the spare icm. So i will only come out spending $170 for the dizzy. Not bad and a learning experience.
kelvinchau25
Aug 29, 2006 07:05 PM
ernald711
Mar 4, 2003 07:26 AM
bluedelsol
Sep 18, 2002 07:35 PM
GTEater
Jun 24, 2001 02:58 PM
