Bearing Question.
Old 01-07-2010 | 08:00 AM
dk4ever's Avatar
Default Bearing Question.
I'm rebuilding my H22 and need help finding the correct set of ACL Race bearings for it. Can anyone help me understand the difference between the std ones and the "extra oil clearance" bearings. I have the part numbers, just don't know which ones to order. The motor is an JDM H22a but it is a Euro-R. Any help on this matter would be greatly appreciated.
Old 01-07-2010 | 04:29 PM
gstrudler's Avatar
Default Re: Bearing Question.
Pretty much exactly what they say, the standard bearings are meant to be within stock specs for clearance, the extra clearance ones would be a slightly thinner bearing, allowing more oil to flow through. If you aren't measuring clearances, I would probably go with the standard ones. Too much oil and it will just wash around instead of creating the film layer it should, and will also not transfer heat as well.
Old 01-07-2010 | 07:25 PM
dk4ever's Avatar
So should I run the race bearings, or the regular bearings?
Old 01-09-2010 | 09:56 PM
gstrudler's Avatar
I'm assuming your car is not a track car that is being rebuilt often, so I suggest the regulars.
ACCORDPRIDE
01-08-2010 02:36 PM
ranta18
02-28-2006 06:35 AM
B20luda
12-19-2004 02:47 AM
PSI-spec
02-16-2003 07:18 PM
Quick Reply: Bearing Question.
