Building Block
Old Jan 4, 2010 | 04:10 PM
H22SHtec's Avatar
Default Building Block
starting to gather parts to build my 97 lude. not sure what bottom end i should go with, h22 or h23 or how much i should bore it. i plan on going 3 angle valve job with a mm over on the valves but my main goal is to jrsc it. looking for the good and the bad or even suggestions for where i should start.
thanks!
Old Jan 4, 2010 | 04:24 PM
KreLude's Avatar
Default Re: Building Block
HERE
Old Jan 4, 2010 | 04:44 PM
NirVTEC's Avatar
Originally Posted by KreLude
LOL
Old Jan 4, 2010 | 07:53 PM
gstrudler's Avatar
If you want to overbore more than .25mm over, you'll have to sleeve the motor. Oversized valves will not likely do a lot for you.
Old Jan 4, 2010 | 09:27 PM
H22SHtec's Avatar
yea here is where im starting lol. im just figuring while the head is going to be ported and all that i might as well do the valves while its apart. not sure what to run for cams either. would like to keep it close to a dd. not sure what bore size either.....
Old Jan 5, 2010 | 04:23 PM
q16racer's Avatar
choose your cams before you put the rest of the build together. They are the HEART of a package.
________
Kawasaki zx600m
Old Jan 5, 2010 | 05:13 PM
NirVTEC's Avatar
You mean THE POWER is in the HEAD? Theres nothing special about some bore/stroke setup?
Old Jan 5, 2010 | 06:09 PM
H22SHtec's Avatar
yea i want a good lift but i dont want it to sound like its gona die when i roll up to a red light. gona buy a H22A4 bare block this weekend so that i dont have to worry about my ATTS.
thanks
rumo1112
Feb 6, 2011 06:27 PM
rumo1112
Feb 6, 2011 01:18 PM
ChaseIntegra
11
Jul 13, 2006 08:45 PM
NewOrleansH22
May 7, 2005 09:36 AM
