RAD Fan wiring
RAD Fan wiring
I put a FAL fan in when I dropped the h22a into my civic and I am not sure where i should hook the fan wires to? I imagine the thermoswitch is what turns on the fan when it reaches a certain temp but where do i tap into it for my 12V power to my fan? any help would be appreciated.
New User
Re: RAD Fan wiring (Alstare)
If ya don't know you can always just make a regular on/off toggle in the cabin area of your ride. It would be really simple to do.
you can run the wires to the stock wires, just cut off the harness and solder on your FAL fan wires. if not, you can do a toggle switch as suggested earlier. thats what i did, i used the ground from the stock fan harness and ran a power straight to the battery, but in bw the power wire is a toggle switch located in my center console so i can turn them on and off.
tigerwing
05-28-2010 09:25 AM
