ATTS Problem Help!!!!!!
Old Oct 31, 2002 | 05:18 PM
spoon99's Avatar
Default ATTS Problem Help!!!!!!
Hey~ After I change my cat to a test pipe, My ATTS light cames ON. Does it means I lose my ATTS or???? If I do How can I have it back...?? If it is possiable.
>"<~please help me with this and forgive me with my poor English..
A little Guy from Taiwan
Old Oct 31, 2002 | 09:30 PM
SuperSH's Avatar
Default Re: ATTS Problem Help!!!!!! (spoon99)
If the ATTS loght is on the ATTS is not working. Check the CEL codes. You may have to implement the OBDII workarround to fix the CEL problem. Its the only way to keep the ECU from freaking out when it thinks the cat is not working/missing.
Old Oct 31, 2002 | 11:42 PM
spoon99's Avatar
Default Re: ATTS Problem Help!!!!!! (SuperSH)
Thx~~very much
I will try to play around with it....
Old Nov 1, 2002 | 06:02 AM
TimeRacer's Avatar
If you're using a test pipe you're getting a CEL light as well. The CEL light will be for either your secondard O2 sensor failure or catalyctic converter failure. You can throw a 10 ohm resistor on the o2 connection and solve the problem.
Old Nov 1, 2002 | 06:39 PM
spoon99's Avatar
Default Re: ATTS Problem Help!!!!!! (TimeRacer)
thank you!!! You are my Hero!!
BrianCivicDX
Oct 25, 2006 05:50 PM
korney
Oct 18, 2006 03:21 PM
Qwikrex
Apr 11, 2002 05:17 PM
EGhatched
Mar 22, 2002 11:04 AM
ITR 00-1567
Mar 16, 2002 10:07 PM
