H23 compression #'s
Old Nov 4, 2002 | 07:18 PM
LudeyKrus's Avatar
Default H23 compression #'s
What are good compression numbers for a stock H23? Need to know for a compression test. Also, for H22's, if ya know(friend is also doing one)
Old Nov 4, 2002 | 07:38 PM
BoostedH23a1's Avatar
Default Re: H23 compression #'s (LudeyKrus)
i hit 207 for the low and 212 was the highest
do a wet and a dry test.. they shouldnt vary more than 15psi or so..
Old Nov 4, 2002 | 07:53 PM
user 9782082308's Avatar
Default Re: H23 compression #'s (BoostedH23a1)
Stupid question. Whats a wet and dry test?
Thanks
Old Nov 4, 2002 | 08:21 PM
93 VTEC's Avatar
Default Re: H23 compression #'s (racerx)
Thanks
If you suspect leaking piston rings put a small amount of oil down the cylinder, it will seal the rings enough to perform a compression test. If the #'s improve suspect bad rings. If they dont, suspect head gasket or, more likely, valves.
Old Nov 4, 2002 | 08:39 PM
H23ludedude's Avatar
Default Re: H23 compression #'s (93VTEC)
around 200 - 210 is good. Make sure the motor is hot. Numbers should be within 10% of each other.
Old Nov 5, 2002 | 05:43 AM
LudeyKrus's Avatar
Default Re: H23 compression #'s (H23ludedude)
Thanx for the info. If I suspect valves, how would I go about doing a leak down test? Or is it even necessary? Also, how much oil for a wet comp. test, and will it crank afterwards?
[Modified by LudeyKrus, 2:44 PM 11/5/2002]
Old Nov 5, 2002 | 08:41 AM
BluLuder's Avatar
Well before I went turbo I turned out..
150 160 150 150 (dry test)
trouble free for over a year a 7-9 psi daily
Old Nov 5, 2002 | 03:55 PM
Default Re: H23 compression #'s (BluLuder)
eww low numbers man.. leak down is u take an air compressor and fill the cylinder up with air pressure through the spark plug hole. (yea its a special tool most compression guages you just disconnet and hook up air hose to it...) then let it sit for a few and put the guage back on it. basicly its not really gonna tell u if its the valves or the piston rings..
Old Nov 5, 2002 | 08:02 PM
Speedy Gonzalez's Avatar
For your friend, a JDM H22A (mine) did 255 250 255 255 (dry test) , USDM H22A should be lower.
Old Nov 6, 2002 | 04:26 AM
Arch-Angel's Avatar
Are you saying that the 7-9psi eventually killed your motor?
I want to put about 7-9 psi in a relativly stock H23 with about 8.5-9:1 CR, and I am wondering if it will eventually kill the block...
Old Nov 7, 2002 | 09:44 PM
SuperSH's Avatar
Default Re: H23 compression #'s (Arch-Angel)
I just did mine today 99' USDM H22a4 and the numbers were 240 across the board no more than three psi diffrence. Is this what everyone else is getting for 5th gen dry tests on a warm motor.?
SilkyJohnson
13
Feb 15, 2011 05:54 PM
turbosivtec
May 24, 2009 04:33 PM
humboldt_skim
May 31, 2008 08:18 AM
Propulsion
Jun 5, 2002 11:48 PM
lazyguy
May 5, 2002 01:36 PM
