fmax install
Old Nov 9, 2002 | 11:41 AM
ketchup_gsr's Avatar
Default fmax install
hi, i was wondering if anyone knew what to do with the replacement MAP sensor they give in the kit. Are we supposed to hook the map electrical and vacuum lines into this new sensor and just leave the old map sensor unconnected? Thanks, i think this is for tne MF2 install...
Old Nov 9, 2002 | 01:02 PM
DirtyLude's Avatar
Default Re: fmax install (ketchup_gsr)
The new MAP sensor connects directly to the MF2. You do not disconnect the stock MAP sensor and you still need to use a check valve so te stock MAP sensor does not see positive pressure. How to hook up the MAP sensor is in the MF2 manual.
JayDMJ
Engine Management and Tuning
Sep 9, 2017 12:24 PM
ketchup_gsr
Sep 8, 2004 08:50 PM
1.8T_EG
May 12, 2003 09:58 PM
austrian type-R
Sep 1, 2001 05:16 PM
