Check engine light blinks TWICE need HELP ASAP
I need help right away help would be greatly appreciated, its a 95 Prelude SI 2.3ltr At a dead stop the engine idle drops then it shuts down entirely. My Best guess is the Throttle Position Sensor. PLEASE ANY IDEAS......
Thanks
AprilzWarrior
Thanks
AprilzWarrior
Re: Check engine light blinks TWICE need HELP ASAP (GudeH23a)
Umm I got in, Started it, wait till it warms up then pow I the light comes on, 1 long blink, then 2 short blinks thats all Ive done so far....
Aprilz
Aprilz
Re: Check engine light blinks TWICE need HELP ASAP (AprilzWarrior)
http://www.hondaprelude.to/main_checkengine.html
Code 12
EGR Valve Lift Sensor
- Lift Insifficient Detected
- High Voltage
Probable cause:
EGR Valve (with lift sensor)
EGR valve lift sensor circuit
EGR control solenoid valve
EGR control solenoid valve circuit
EGR line
ECM (ecu)
Code 12
- High Voltage
Probable cause:
EGR line
ECM (ecu)
Ok Ive looked into the Throttle Position Sensor and the Stealor wants to sell me the entire Throttle Body Assembly for over 500... WTF ?? Could this entire problem be the EGR ??? Please help !!!!
Ive also done a complete tune up, Plugs. Wires. Cap. Rotor. PCV valve. Fuel Filter.
Please Please Please Help !!
Aprilz
Aprilz
New User
let me know I also have kinda same prob irratic idle unless all electrical devices are on then when coolant fan turns off it acts up again I am going to change the tps on the back of the tbody that's my last option I beleive
Re: Check engine light blinks TWICE need HELP ASAP (oldirt3277)
Guess what man, if you plan on changing the TPS, the Stealor says the entre Throttle Body must be changed as well !!!!
Anyways, Why would it be your TPS if you're getting an EGR code? They are not related.
[Modified by satan_srv, 8:29 PM 11/4/2002]
cprlover
12-07-2010 04:35 PM
