Car shaking/bouncing
Old Nov 1, 2002 | 04:06 PM
ZoNe_HKS's Avatar
Default Car shaking/bouncing
couple weeks ago i realized my car bounces/shakes alot, can this be suspension or if wheels messed up, i try to get my wheel balanced to fix the problem. instead it got worse haah, i did find that left front wheel is a lil cracked and right front wheel is bent a lil, but someone told me this could be suspension, anyone know??? i plan to get new wheels, but i dunno if i should get new suspension as well, i push down on all 4 shocks, it came up fine, and i feel the suspension is fine......
Old Nov 1, 2002 | 04:09 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Car shaking/bouncing (PDP_HKS)
did u get an alignment as well, what about having your brakes checked? could be warped rotors
Old Nov 1, 2002 | 04:12 PM
ZoNe_HKS's Avatar
Default Re: Car shaking/bouncing (Boosted97Lude)
highly unlikely, because i just changed my brakepads.. rotors seems fine, and **** bounce/shake when i dont brake haha, could be alighment but i dont see how this problem just all of a sudden appears
Old Nov 1, 2002 | 04:14 PM
Boostless97Lude
Guest
Posts: n/a
i wouldn't think that your rims could cause this, but if they are bent and out of round, i guess it's possible, but i doubt that it's with your suspension
Old Nov 1, 2002 | 04:21 PM
Cottonwoodz's Avatar
lower ball joints ?
Old Nov 1, 2002 | 09:36 PM
NONKonformyst's Avatar
How do your tires look? Are they bald? Or are they unevenly worn? That is usually a culprit. Other than that a ball joint possibly, i've seen it many times.
Old Nov 1, 2002 | 09:39 PM
ZoNe_HKS's Avatar
Default Re: Car shaking/bouncing (95redLUDE)
tires are fine, only like 4-5k on them checked looks new, yea i will get the ball joint checked out, thanks guys
Old Nov 2, 2002 | 12:01 AM
SuperSH's Avatar
Try rotating your wheels to see if the shaking moves (i.e. move the front wheel to the back or left to right) If the shake stops or moves to another wheel then you have a culpret. If it stays in the same place then consider the suspension (ball joint etc.)or shock/strut. My roommate bought a set of used tires and thought they were out of ballance too untill I put his car on jackstands to show him the bent wheel. He wondered why the wheels came with one new tire.... $210 later his car rides better. Sorry so long...
loki2323
13
Aug 17, 2014 05:12 PM
ViperBLUE EJ6
Jan 1, 2010 07:57 PM
vladd
Mar 27, 2008 07:20 PM
Ditdogs
Mar 29, 2004 03:10 PM
