H22 INJECTOR ?
Old Aug 31, 2003 | 03:19 PM
H22AJSPEC's Avatar
Default H22 INJECTOR ?
I HAve an h22 11.5:1 comp and am running 450cc injectors (way rich) . im looking at getting a set of r.c. injectors what size would you guys recomend 310cc ?
Old Aug 31, 2003 | 07:46 PM
str8rcn's Avatar
Default Re: H22 INJECTOR ? (H22AJSPEC)
You can call the guys at Venom and tell them your HP goals and thay can help you or check here http://www.rceng.com/technical.htm#WORKSHEET
Old Aug 31, 2003 | 10:34 PM
d98clturbo's Avatar
the stock h22 injectors are 340cc why not use those
Modified by d98clturbo at 3:01 AM 9/2/2003
Old Sep 1, 2003 | 11:38 AM
macswhtaccord's Avatar
Default Re: H22 INJECTOR ? (d98clturbo)
h22a stock injectors are 345cc, so you would be downgrading going with 310cc.
Old Sep 1, 2003 | 12:29 PM
mattmw88's Avatar
Default Re: H22 INJECTOR ? (macswhtaccord)
how do you know the stock sizes? I heard from RC injecters that the stock ones are 245 or 265(I forgot which). I just want to know the truth.
Old Sep 1, 2003 | 12:42 PM
Furry in your eye
Guest
Posts: n/a
Default Re: H22 INJECTOR ? (mattmw88)
the truth............
obd1 h22 345cc
obd2 h22 290cc
Old Sep 1, 2003 | 07:45 PM
Default Re: H22 INJECTOR ? (Furry in your eye)
I've had mine cleaned and flow tested. They're 345cc.
Old Sep 6, 2003 | 12:05 AM
h22allmotor's Avatar
Default Re: H22 INJECTOR ? (str8rcn)
I HACE 320 CC FOR YOUR CAR FROM RC
DA is best
May 7, 2012 10:32 PM
AndyD
Oct 3, 2003 11:30 PM
boonacka
Sep 16, 2003 09:41 AM
