what is code 21?
Old Aug 26, 2003 | 09:44 AM
F120man's Avatar
New User
Default what is code 21?
what is code 21? i have a h22aEG thats just started, and its putt out code 21. never heard of it.
Old Aug 26, 2003 | 01:07 PM
Ferrell's Avatar
Default Re: what is code 21? (J B G)
Is it the CEL or ABS?
In my 98 Integra Supplement, Code 21 is from the ABS :
Code 21-24
- Pulsar
Not sure if this will help any, just thoughd id try
Old Aug 26, 2003 | 03:13 PM
F120man's Avatar
New User
yeah its code 21, because it has 2 long blinks and 1 quick one.
Old Aug 26, 2003 | 03:46 PM
Hondaaccordvtec's Avatar
Default Re: what is code 21? (F120man)
This is right from my Helms manual (for a '94 Prelude) -
CODE 21 = Variable Valve Timing & Valve Lift Electronic Control Solenoid Valve.
You can check the solenoid by doing a continuity test. Probe the connector terminal and then take the other probe and touch a GOOD grounding point. If you get a reading of 14 - 30 ohms, you have a good VTEC solenoid valve. If you get a number below 14 or higher than 30, you have a BAD valve - replace it.
Old Aug 26, 2003 | 05:04 PM
F120man's Avatar
New User
Default Re: what is code 21? (Hondaaccordvtec)
thanks alot, will check it when i get home
asocallocal
Jun 6, 2010 11:30 AM
Rukusmasta2
Mar 4, 2006 09:21 AM
fassassin
Jan 8, 2005 05:17 PM
Que_Lude
Jan 18, 2003 12:34 AM
