oil pressure problem
Old Dec 8, 2003 | 02:23 PM
boostlee's Avatar
Default oil pressure problem
hey all, have a problem, i changed the oil on my car and when i started it up the oil light stayed on.
i checked the level and it was fine, don't know if something is clogging the passages. i am going to pressure test it when i get the pressure gauge
any ideas??
thanks
Old Dec 8, 2003 | 03:09 PM
graphic's Avatar
Default Re: oil pressure problem (boostlee)
bad sender???
Old Dec 8, 2003 | 07:12 PM
boostlee's Avatar
Default Re: oil pressure problem (boost-stupid)
**** **** ****, the problem was the damn k&n oil filter. did not allow oil to flow and cause my cam bearings to get fcuked, put back a stock honda oil filter and changed the oil. got alot of brass metal shavings from the oil.
**** **** ****, i'm pissed off.
car still runs decent, i will changed the oil and oil filter another two times this week to get out all the brass shavings. then i will see how bad the damage is.
******* k&n filter, do not use if you have a B&M oil filter relocation kit on
Old Dec 8, 2003 | 07:33 PM
fastludeh22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostlee &raquo;</TD></TR><TR><TD CLASS="quote">**** **** ****, the problem was the damn k&n oil filter. did not allow oil to flow and cause my cam bearings to get fcuked, put back a stock honda oil filter and changed the oil. got alot of brass metal shavings from the oil.
please explain what the problem was, kit or user error
Old Dec 8, 2003 | 08:21 PM
boostlee's Avatar
Default Re: oil pressure problem (fastludeh22)
bad K&N oil filter, was restricting the oil flow somehow. i have used the k&n oil filter in the stock location but never with the oil relocation kit.
when i put on a new honda oil filter.....bam oil pressure light went out and i had oil pressure.
something so simple, but i never would of thought, partly my fault
Old Dec 8, 2003 | 10:45 PM
Eddiebx's Avatar
damn that sucks, good thing I've been to lazy to switch to K&N oil filters, imma stick to mobil 1. but how do you have cam bearings?
Old Dec 8, 2003 | 11:33 PM
dankbudz11357's Avatar
Default Re: (Eddiebx)
damn and i use those things when i change my oil. guess oem honda sounds good right about now
v8killaz
Nov 20, 2009 03:21 PM
racingfan
Aug 14, 2006 02:18 PM
EJ8VTEC
46
Sep 8, 2005 08:22 PM
hondapwr
Mar 11, 2004 02:43 PM
john94si
Honda Motorcycles
Jun 27, 2001 08:07 AM
