Tranny Problems
Old Dec 14, 2003 | 01:29 PM
Taikonaut's Avatar
Default Tranny Problems
Alright well not sure what happened, or what's wrong so I'll ask here.
Yesterday it drove fine and everything worked and was good. I was able to shift gears and everything normally. Now today when I try and goto work I can't shift into gear, unless you push it hard into gear.
When the car is off I'm able to shift into all of the gears w/o pressing the clutch at all, it goes into every gear fine. But once the car turns on I can't get into any gear.
Anyone know what's up?
Old Dec 14, 2003 | 01:31 PM
AndyD's Avatar
Default Re: Tranny Problems (Taikonaut)
https://honda-tech.com/zerothread?id=705727 ???
Hey, can you put the car in gear while it is off....then hold the clutch in and then try to start the car?? Let me know what happens. Also, if you ge tit repair PLEASE let me know what the tech says was the issue.
Old Dec 14, 2003 | 01:35 PM
Taikonaut's Avatar
Default Re: Tranny Problems (AndyD)
Yeah when the car is off I'm able to shift into every gear, even if I'm pressing the clutch or not. But right when it turns on I'm not able to shift it at all unless I SHOVE it into gear.
I'm gonna try and have someone look at it tommrow and see if I can get it fixed.
Old Dec 14, 2003 | 03:26 PM
PR_Prelude's Avatar
I would check the master cylinder and the slave cylinder. Same thing happened to me. One day it was fine, the next day the gears wouldn't get in.
Old Dec 14, 2003 | 04:33 PM
SKDRCR's Avatar
Default Re: (PR_Prelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PR_Prelude &raquo;</TD></TR><TR><TD CLASS="quote">I would check the master cylinder and the slave cylinder. Same thing happened to me. One day it was fine, the next day the gears wouldn't get in.</TD></TR></TABLE>
w3rd,..... check fluid first
Old Dec 14, 2003 | 07:53 PM
Taikonaut's Avatar
Alright I'll try and do that tommrow.
Old Dec 15, 2003 | 09:37 AM
Taikonaut's Avatar
Ok So I checked all 3 of the reservoirs today and they all were full. Like not to the tippy-top of the brim but most of it is. I circled which ones I checked in the pic. Did I not check the right one, or is it something else?
Old Dec 15, 2003 | 09:52 AM
AndyD's Avatar
The small one on the right side s the clutch reservoir. The other two are the brake fluid and ABS fluid.
Old Dec 15, 2003 | 10:26 AM
Taikonaut's Avatar
Alright thanks, just wanted to make sure I checked the right one.
So far I've heard change the tranny oil and it will fix, fill up the clutch reservoir, bleed the clutch reservoir, clutch spring and the whole clutch.
I figure I'm just gonna try the cheaper fluid stuff first and hope that it ends up fixing it.
Old Dec 15, 2003 | 03:32 PM
PR_Prelude's Avatar
Do something first, get beneath the dash, and check the rod that connects to the pedal, if it's greasy, you got a bad cylinder.
Old Dec 15, 2003 | 04:37 PM
BoostedH23a1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PR_Prelude &raquo;</TD></TR><TR><TD CLASS="quote">Do something first, get beneath the dash, and check the rod that connects to the pedal, if it's greasy, you got a bad cylinder.</TD></TR></TABLE>
also u can adjust the clutch here..
jaydem7
12
Sep 2, 2007 05:12 PM
JDMGSR-T
Oct 27, 2006 02:48 PM
silent-chris
Honda S2000
Sep 17, 2006 09:00 PM
eMbrace
May 14, 2005 07:47 AM
AznBlueBoy
Oct 26, 2004 04:33 AM
