radiator question..
Old Dec 12, 2003 | 04:32 PM
93vtec's Avatar
Default radiator question..
the 92-96 preludes all used the same radiator rite?? like the s model si and vtec all had the same radiator right?? because mine busted and i came across a cheap used one.. let me know if all the models share the same one or not thanks.
Old Dec 12, 2003 | 04:43 PM
biglew's Avatar
No.
Old Dec 12, 2003 | 06:29 PM
SKDRCR's Avatar
Default Re: (biglew)
maybe not, but i don't see why you couldn't make it work
Old Dec 12, 2003 | 06:32 PM
PrecisionH23a's Avatar
Default Re: radiator question.. (93vtec)
I believe the dimensions of the H23a are a tad bit larger then the h22a.
I am not sure about the mounting locations though. If you have a h22a I'm sure you can use the h23a one, you might need to make minor adjustments to the mounts though.
Old Dec 12, 2003 | 06:37 PM
93vtec's Avatar
coool... thanks for all the quick replies
Old Dec 12, 2003 | 06:41 PM
biglew's Avatar
You should just save yourself the trouble and get the proper one. I have a Prelude S radiator and my car is VTEC the rasdiator sits right but the fans don't bolt up on the proper points. I had to do some janky ghetto riggin to get my fans to stay (copper wire and duct tape). Not to mention that I had to clip the edges of my radiator fan blades because they were hitting the front engine mount.
Old Dec 14, 2003 | 02:06 PM
VTECRaZeR's Avatar
Yea...Mounting on H22 radiators is a little different then H23s radiator. But the main thing is the mounting of the fans. I my self have a H23 radiator on my H22, but I have the H23 fans too, so it all matches.
Old Dec 14, 2003 | 02:11 PM
buh_buh's Avatar
I believe the Prelude S radiators were only half rads too.
Old Dec 15, 2003 | 01:47 PM
biglew's Avatar
Type S radiators are not half.
yz125rider21
15
Jan 7, 2008 11:42 PM
spoolin_teg
Dec 21, 2006 03:26 PM
drewbie
Sep 28, 2004 12:11 PM
viet4gvtec
May 5, 2003 11:25 AM
cecknight
Jul 13, 2002 06:52 AM
