fuel filter
Old Dec 7, 2003 | 06:04 PM
99lude's Avatar
Default fuel filter
When do i have to replace my fuel filter... i don't think it is part of the routine maintenance at dealers? i have 102K on my lude rite now, the idling was bad(around 400-500rpm), but after i replace my plugs, it was ok (around 700-800 rpm), but it makes a slight noise... kinda like sputtering...
do i have to get underneath my car to replace it??
Old Dec 7, 2003 | 06:35 PM
SKDRCR's Avatar
Default Re: fuel filter (99lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lude &raquo;</TD></TR><TR><TD CLASS="quote">
do i have to get underneath my car to replace it??</TD></TR></TABLE>
i don't think so (it's located near the firewall on 4th gen's at least )
if it's never been changed, might be woth a try
Old Dec 7, 2003 | 06:44 PM
99_SH's Avatar
The fuel filter is located on the firewall, towards the driver side. Its a real pain to change, and you have to have some special tools(flare crow-foot socket). Loosening the banjo bolt on top of the filter is easy, but loosening up the nut underneath takes a bit of effort.
Have fun doing it... --and yes, you need to get under the car to remove it!
Old Dec 7, 2003 | 06:57 PM
SKDRCR's Avatar
Default Re: fuel filter (99_SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_SH &raquo;</TD></TR><TR><TD CLASS="quote">The fuel filter is located on the firewall, towards the driver side. Its a real pain to change, and you have to have some special tools(flare crow-foot socket). Loosening the banjo bolt on top of the filter is easy, but loosening up the nut underneath takes a bit of effort.
Have fun doing it... --and yes, you need to get under the car to remove it!</TD></TR></TABLE>
must be harder then the 4th gens
mine took about 10 min
Old Dec 7, 2003 | 07:03 PM
Behan's Avatar
Default Re: fuel filter (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
mine took about 10 min </TD></TR></TABLE>
i was going to say the same thing, mine took about 10-15 mins too.
Old Dec 7, 2003 | 07:10 PM
boostlee's Avatar
change the filter, it will help if its never been changed.
http://www.cardomain.com/id/boostlee
Old Dec 8, 2003 | 04:52 AM
MechEng's Avatar
Default Re: fuel filter (boostlee)
Your supposed to change it every 96,000km
I have a 4th gen, it was pretty easy except the bolts were torqued to hell.
I needed a breaker bar to remove them.
Old Dec 8, 2003 | 06:57 AM
93ludeSi's Avatar
yeah, i have a 93 si, is was a simple change other then the bolts were very tight, and i DO NOT remember have to climb under the car, the filter is directly to the right of the fuse/relay box under the hood
jhony_ej6
Jul 11, 2008 09:55 AM
jmaz
Honda Civic (2006 - 2015)
Aug 8, 2007 04:30 AM
Rpizzle
Apr 7, 2005 09:37 AM
namja9487
Jul 23, 2004 08:41 AM
WayneGro
Oct 24, 2003 04:58 AM
