Clutch problem
Old Dec 10, 2003 | 11:14 AM
2.2SICKLUDE's Avatar
Default Clutch problem
My clutch won't let me shift into any of the gears, my buddy said that it's probably the clutch hydralic fluids or something, or that there might be a leak on the lines. The weird thing is that I turned off the motor and turned it back on and it worked for a bit drove it around and then it started doing the same thing? Anyone got any other answers thanks..
Old Dec 10, 2003 | 12:08 PM
Sephro's Avatar
Default Re: Clutch problem (JDMH22NLINE4)
have you checked the fluid level?
Could be a a busted spring on the clutch plate too. Does it make any noise?
Old Dec 10, 2003 | 12:36 PM
Foozball26's Avatar
Default Re: Clutch problem (Sephro)
if you have a leak in the clutch line it will not build up enough pressure to operate it.
Check all the fittings on the clutch line to make sure they are not leaking and make sure they are tight. Then try and bleed the clutch with all new fluid.
Old Dec 10, 2003 | 05:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sephro &raquo;</TD></TR><TR><TD CLASS="quote">have you checked the fluid level?
Could be a a busted spring on the clutch plate too. Does it make any noise? </TD></TR></TABLE>
No noise, only thing is that when i step down on the clutch there seems to be no pressure, and the clutch is stuck at neutral, it won't engage into any gears at all. I'll check this out thanks
Old Dec 10, 2003 | 05:21 PM
Revi's Avatar
Have someone press in the clutch and you check and look at the slave cylinder to make sure its opening up and engaging the clutch. If your slave cylinder is working properly, its not gonna be a clutch line problem.
Old Dec 10, 2003 | 05:31 PM
Puki
Guest
Posts: n/a
Bah, add Dot 3 brake fluid in your reserve.
It's most likely the most basic of problems.
Old Dec 16, 2003 | 10:08 AM
Default Re: Clutch problem (Revi-Ra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi-Ra &raquo;</TD></TR><TR><TD CLASS="quote">Have someone press in the clutch and you check and look at the slave cylinder to make sure its opening up and engaging the clutch. If your slave cylinder is working properly, its not gonna be a clutch line problem. </TD></TR></TABLE>
The cylinder is not opening, so is it the clutch? My buddy and I just installed the clutch too, maybe w did something wrong
Old Dec 16, 2003 | 10:18 AM
Doc_Honda's Avatar
my 98 was doing the same thing...
Look for fluid around the master cylendar and the slave... I had to replace both recently... but not at the same time...
1st the Master cyl, then 3 months later the slave had to be replaced. Our clutch systems suck.
Old Dec 16, 2003 | 11:20 AM
PR_Prelude's Avatar
Did you disconnected the slave cylinder?? Do a bleed to the system to see if it helps.
Old Dec 17, 2003 | 12:20 PM
Default Re: Clutch problem (Doc_Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doc_Honda &raquo;</TD></TR><TR><TD CLASS="quote">my 98 was doing the same thing...
1st the Master cyl, then 3 months later the slave had to be replaced. Our clutch systems suck.</TD></TR></TABLE>
If it was the master cyl, wouldn't the clutch pedal slowly move upwards once you step down on it? Mine at the moment is all the way down and it won't come back up?
Old Dec 17, 2003 | 12:45 PM
AndyD's Avatar
https://honda-tech.com/zerothread?id=705727
Same issue???
Old Dec 17, 2003 | 12:54 PM
Sephro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22NLINE4 &raquo;</TD></TR><TR><TD CLASS="quote">
If it was the master cyl, wouldn't the clutch pedal slowly move upwards once you step down on it? Mine at the moment is all the way down and it won't come back up?</TD></TR></TABLE>
That sounds like you need to bleed the system bad.
Old Dec 17, 2003 | 01:35 PM
Default Re: Clutch problem (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=705727
Same issue???</TD></TR></TABLE>
Sounds like the same issue but I can't force it into gears, I tried forcing it but it's too hard to push it into the gears. The thing is that my buddy just installed the ACT clutch and this tranny is a used one but I don't think its bad..... I had this happen to me before and my friend said it was the lines leaking or something but he was not sure too because he forgot.
Old Dec 18, 2003 | 01:42 PM
Ok figured out the problem,it was the master cyl. I guess i should just changed out the slave as well.
Old Dec 19, 2003 | 06:51 AM
Doc_Honda's Avatar
No... mine hit the floor too, and stayed there.
Old Dec 19, 2003 | 06:53 AM
Doc_Honda's Avatar
Default Re: Clutch problem (PR_Prelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PR_Prelude &raquo;</TD></TR><TR><TD CLASS="quote">Did you disconnected the slave cylinder?? Do a bleed to the system to see if it helps.</TD></TR></TABLE>
You dont disconnect it... you turn the valve and bleed the system just like brakes.
B18Redline
Nov 13, 2007 11:09 AM
Toretto
Aug 1, 2003 02:48 PM
IDMaxGuy
Jul 28, 2003 10:40 AM
H22Apexi
Jun 5, 2003 01:04 PM
